20 Most Recent Clarion DZX265 Car CD Player Questions & Answers
Does any one know how to adjust the sound on a
It's not the same model, but the DXZ385 may have similar controls. Check the PDF at... http://www.manualslib.com/manual/222923/Clarion-Dxz385.html
6/27/2014 12:10:49 AM • Clarion DZX265... • Answered on Jun 27, 2014
I've got a clarion dzx265
do you have an audio button????????
3/20/2011 4:15:00 PM • Clarion DZX265... • Answered on Mar 20, 2011
Does clarion m5475 have an aux in jack
Hi, I'm not seeing one based on the images that I'm seeing from it's front view. I only see number pads on the right side of the face with and circular arrangement of buttons on the left side of the device. But you can check the back of the device as I see 2 input on the top-right side of the back of the clarion device. Thank you.
1/4/2023 12:31:29 AM • Clarion Car... • Answered on Jan 04, 2023
I have a nx604 clarion when it come on the face says intellgence voice then clarion and nothing else
Hi, when the voice prompt comes on, please attempt to speak the words "factory reset" and check for any activity. Also, if you haven't attempted to restart your car prior to the first recommendation, please do that first before restarting your clarion equipment again. If those steps fail, you might need to process the factory reset via the equipment without using your voice. If you don't have the proper documentation to help guide you through through the reset process, please reach out to clarion by dialing 877-424-6423. Thank you.
1/4/2023 12:23:03 AM • Clarion Car... • Answered on Jan 04, 2023
2answers
Need wiring diagram for 14
http://www.clarionworld.co.uk/car-audio.aspx/iso-connector
12/24/2022 4:47:03 AM • Clarion Car... • Answered on Dec 24, 2022
Hello my car radio Clarion NX110 buttons are not working properly sometimes they work n sometimes not currently for the last 3 weeks they don't respond at how do we reset it to work
If the button is stuck, try to use something small to clean around the button; it may have dirt built up around it causing it to be stuck. Use something small such as a paper clip or a cotton swab to clean around the button. If this does not work, you may need to disassemble the device. https://www.ifixit.com/Answers/View/195905/How+can+I+get+the+buttons+on+my+radio+un-stuck
12/13/2022 7:11:05 PM • Clarion Car... • Answered on Dec 13, 2022
2answers
How do I get code for Clarion radio
Code is 2454
  • Radio Code advice always available here
www.ukbookshelf.co.uk Mention FixYa Forum
12/3/2022 10:40:45 AM • Clarion Car... • Answered on Dec 03, 2022
I have a clarion car radio model PU-2471Z(J) where all buttons on the faceplate have stopped working (increases volume with some)with the exception of the on/off button and cd eject button. Any ideas
Hi, Please hold down the power button until the radio turns on or off (maybe 30 seconds). If this does not work, you can attempt a factory reset if the appropriate buttons are available. Otherwise, you might need to remove the radio from the car (if possible) and take the radio to the nearest Geeksquad/bestbuy for repair. Thank you.
11/25/2022 11:11:14 PM • Clarion Car... • Answered on Nov 25, 2022
2answers
Radio locked need a Code for PU-2294B
Need a Vehicle Radio Code? There are only three ways to do this. 1. Take it to your local local dealership for your make of vehicle. You will need to provide the registration document and they will give you the code for free based on the vehicle VIN Number. 2. Look for a small white sticker in the glove compartment or the centre console. When the car is new, this sticker is supplied with the manual with those instructions. 3. You pay an online Radio Code Decoding company. Many of them say 'Free', but most charge about $15 or £12 UKP. The major sites are trustworthy and will work with you, or refund if the code doesn't work. The sites need the Serial Number of the radio which is either engraved to the radio chassis, or on a sticker at the rear or sides hidden from view. This link is for Fiat, change the Search Query to your make. https://www.google.com/search?q=Fiat+radio+code .. Posted by ADMIN... on May 19, 2022
10/15/2022 12:11:02 PM • Clarion Car... • Answered on Oct 15, 2022
Pos. Neg. Speaker con.on clarion 5780 white with a black stripe pos. Or neg.
Usually the wire with the stripe is negative in my experience. Like on this diamond audio micro 4.
8/2/2022 5:18:23 PM • Clarion Car... • Answered on Aug 02, 2022
2answers
I need to change the language on a Clarion MC314 that's on a Japanese car. Can't seem to get this fixed using the touchscreen settings.
It can be difficult to go through the menu, especially when everything is in Japanese. One of the best workarounds for this is to use the Google Translate app. Go to the Play Store, then download the application on your phone. All you'll need to do is use the camera feature of the app and point your smartphone to the words you want to translate. Once you've done this, the language will appear as English on your phone's screen. Or if it does not works then There are service centers that offer this service, and you can easily find one by performing a quick Google search. They should be able to offer you the appropriate software for your vehicle make and model. Once you've installed the SD card, all you'll need to do is restart the system and it will be in English. Hope it helps you. Good luck
7/22/2022 9:26:48 AM • Clarion Car... • Answered on Jul 22, 2022
Hello! My Clarion PS-2685H-B and SN. 0111051 need a Code? Can you help me?
Yes I can Lerry, I just wrote a FixYa Tip on this subject. https://www.fixya.com/support/r29874205-need_vehicle_radio_code ..
7/10/2022 5:58:57 PM • Clarion Car... • Answered on Jul 10, 2022
What audio formats does the clarion cv737 6 disc cd changer read.
the manual all all those on earth made tells that. i will now google for and read it to you. out of NISSAN? what year? 1995??????? Clarion changer CV737 (Clarion Part Number PN-2144U/Nissan Part Number B8183-C9961)???????????? PN-2144U-C ( C=this is the newer version 2002 I think) a car here, CV737 is only the bracket name. wow. this https://ia802302.us.archive.org/10/items/manual_CV737_SM_CLARION_EN/CV737_SM_CLARION_EN.pdf CD , 1999 CD drives only play 1 disk, called CD_DA aka, as music dicks only. the kind seen in walmart, music disks isle. not mp3 not cd-r no cr-rw not wav files not flac files or any other audio file types(over 50 now) does not. 1999 answer above 2002, I here some play CD-r why not just do it and try, a CD-r is what, 25cent burn." facts are hard to find 22 years later. on old drive. most are dead now and ever bump car hits it changes track, learn to ask car maker for the cars manual on this Deck. only that tells the truth, from 1999. 2002 maxima user guide clear as day stated Do not use the following CDs as they may cause the CD player to malfunction. I3.1 in (8 cm) discs with an adapter IRecordable compact discs (CD-R) IRewritable compact discs (CD-RW) ICDs that are not round ICDs with a paper label ICDs that are warped, scratched, or have abnormal edges ---------------- not one word MP3 there or other like kind codecs)
7/2/2022 4:30:08 PM • Clarion Car... • Answered on Jul 02, 2022
3answers
Hi Please help am Lost code for radio Clarion PU2294A C number CL040151001954C thank you
dealer with vin and proof of ownership
6/30/2022 5:14:03 PM • Clarion Car... • Answered on Jun 30, 2022
2answers
Clarion Car Stereo System PE-2528-KA I need radio code for pe2528ka please.
Question edited for full make model (what it is). Question moved to Clarion. You have to contact Clarion showing ownership papers. Or you can pay an online radio coding company based on the serial number. . https://www.google.com/search?q=Clarion+pe2528ka+code ..
6/25/2022 11:36:58 AM • Clarion Car... • Answered on Jun 25, 2022
2answers
Need to find wiring diagram for clarion 100eqb-5
You should refer to Youtube,YouTube, found a video on their site and it was very helpful.
6/25/2022 12:52:44 AM • Clarion Car... • Answered on Jun 25, 2022
I have 2 Clarion 100EQB-5
6/25/2022 12:45:23 AM • Clarion Car... • Answered on Jun 25, 2022
2answers
Wiring diagram for a Clarion 100EQB-5
Yes. Recommend contacting a local car audio professional or Clarion customer support directly here: https://clarion.com/xe/en/user-support/inquiry/contactus helpful-j2fqtt4x4km4a1x1cbly0mof-5-0_12.png
6/25/2022 12:44:12 AM • Clarion Car... • Answered on Jun 25, 2022
Clarion DZX265 Car CD Player Logo
2 questions posted
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Clarion Car Audio & Video
Most Popular Question
any one know adjust sound
  • Car Audio & Video
