20 Most Recent
Kenwood KDC-MP442U Questions & Answers
Kenwood kdc-mp442u protect mode came
First of all , your Kenwood shows only Protect on the display when your speakerwires are conflicting with each other , but when you cannot find the problem there....
disconnect them one by one to see wich speaker in your car is conflicting (shortcuts).
Replace that speaker and your kenwood will work just fine.
I had the same problem here with a brand new Clarion speaker .
6/11/2015 9:10:39 PM •
Kenwood...
Answered
on Jun 11, 2015
How to unlock radio kdc-mp442u
If you have no code the Kenwoods have to be sent for re-coding as it cannot be done on line.
Good luck with it
3/20/2011 10:45:27 PM •
Kenwood...
Answered
on Mar 20, 2011
My subwoofers don't work
Check the fuse on the amp.
Plug a different source like an iPod into the amp to ensure that the subs and amp still work.
If your still not getting anything I would recommend visiting a reputable car audio shop in your area and getting them to check over the system.
2/4/2011 4:37:21 AM •
Kenwood...
Answered
on Feb 04, 2011
I have a Kenwood KDC-MP442U Deck and protect will not come off
check speakers for a short protect means one of the speakers are shorting so check all the connections on speakers or if you have a multimeter put the black to ground and put it on contanuity and check from the plug at the unit and it will beep if one is shorting then you know which one to check instead of pulling your whole car apart:)
4/27/2010 12:43:06 AM •
Kenwood...
Answered
on Apr 27, 2010
I'm quite sure my cars aftermarket deck is
if you have a multimeter you should check your speakers to see how much resistance they have. if less than 3 or 4 ohms, you may have bad speakers.
also, the speakers may be wired improperly.
3/8/2010 5:13:40 PM •
Kenwood...
Answered
on Mar 08, 2010
