20 Most Recent
Nokia BH500 Bluetooth Headset For N95 8GB 6500 UK Questions & Answers
The display of my phone is working but for last 2
Hi, possible causes for horizontal line on screen are,
Phone Screen problem and,
The flex of a phone.
When a screen displays horizontal lines on the screen, is when screen of the phone is getting damaged due to phone falling on the ground,or hitting phone on an object can cause horizontal line on a screen.
Solution to this problem is to replace the screen of the phone.
The flex of the phone can also cause horizontal lines on a screen. The flex is a thread like object inside the phone that makes the phone to function properly in terms of the display..
When the flex is getting damaged, it can cause such horizontal line on the screen display.
Solution for this problem,is to replace the flex.
Note : flex can be found only on slide phones.
Thanks for using fixya........
Hello
I have just bought a
Hi,when you want to connect a Nokia Bluetooth stereo headset BH 505 to a phone all you need is a default code which "0000" and your done Try it it works like magic...Or you can choose to useany other code, but the code must be 4 digits.....
Thanks for using fixya...............
I was playing around with my puk codes and sim
your PUK-code and PIN-code were delivered together with your sim-card. when the sim-card asks for a PUK, it is blocked until the PUK-code is entered. if you cannot find the PUK-code anymore, it is advisable to go to your service provider (cell phone dealer) and ask for a new sim-card with the same number. hopefully you had your contacts saved to your phone and not to the sim-card, because it's very unlikely that any data on a blocked SIM can be retrieved.
