20 Most Recent
Motorola Mobility H681 Bluetooth Headset Questions & Answers
My phone is saying that
The solid blue light is pairing mode, so you are doing it right. Try shutting both the phone and the H681 off, and turning them back on. We had a similar problem with my girlfriend's new motorolla headset while pairing it to a samsung vibraint. It worked for us after we did that.
5/9/2011 7:35:55 PM •
Motorola...
Answered
on May 09, 2011
I have a Motorola H681 that used to work fine, now
I was having the same problem - I ended up just playing with it until it worked again. I found instructions on muting the H700, which is to tap both volume buttons at once. I did that a few times while on a call (I was actually listening to my voicemail), and then I hit the volume up button, and now it works. Not sure if something is loose inside and all I had to to was play around to get it back into place?
5/4/2011 8:28:08 PM •
Motorola...
Answered
on May 04, 2011
H681 wont' pair with iphone
Select YES to pair. Enter the passkey 0000 and select OK.
if you have any OTHER devices paired remove them.
1 reset network settings on iphone
2 power off blue tooth device
3 power cycle iPhone
4 attempt to re-pair
3/7/2011 4:25:36 AM •
Motorola...
Answered
on Mar 07, 2011
Whats the pass key
Thanks for using FixYa.
The passkey is
0000 (four zeros)
For more details, download and refer to the manual in PDF format by clicking this
link.
Please note:
Adobe PDF Reader is required to view this manual.
Click here to download the latest version of Adobe Reader.
2/7/2011 12:30:25 PM •
Motorola...
Answered
on Feb 07, 2011
Misplaced manual for bluetooth Motorola h681 need
Your headset's passkey is '0000' (four zeros). I couldn't find its user guide, but the one for the H680, which happens to be very close to yours, can be found
here.
Hope you are able to sort your problems out soon.
Regards,
Carlos
8/18/2010 1:09:07 AM •
Motorola...
Answered
on Aug 18, 2010
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
