20 Most Recent Samsung WEP350 Bluetooth Headset Red Questions & Answers
0answers
Listen music
Be the first to answer 6/11/2013 10:01:54 PM • Samsung WEP350... • Posted on Jun 11, 2013Be the first to answer
I need help now
What is the problem you're experiencing? What is the phone you're trying to pair the headset with?
11/12/2010 9:25:42 PM • Samsung WEP350... • Answered on Nov 12, 2010
3answers
Where would i find a
Hi Moralesdee52,
The passcode for this headset is usually 0000 (Four zero's)
If you no longer have the manual you can have a look at the quick start guide for your device here:
Samsung WEP350 Quick Start Guide
This is a PDF file and normally opens on its own as the webpage.
I hope this helps.
Kind Regards
Mike
11/9/2010 4:56:39 PM • Samsung WEP350... • Answered on Nov 09, 2010
0answers
2answers
I want the passcode for sumsung wep350
Have you tried the default 0000 or 1111?
Stelios.
3/1/2010 1:21:40 PM • Samsung WEP350... • Answered on Mar 01, 2010
Have a samsung finesse and i need help paring my
1- First turn on Bluetooth function on the Finesse.
2- Then start the pairing mode on the headset (for a Jawbone, make sure it is turned off then press the Noise Shield button for 3 seconds, the LED will begin to flash Red then White.
3- Back on your Finesse you should have the Bluetooth screen up with the search button in center, Press the Search button.
*the search & pairing process takes a minute or two, wait untill your headset finishes and stops blinking.
4- You should now show your Bluetooth device on your Finesse screen.
5- Now with your finger, Press,Hold and Drag the newly found headset icon onto the Search button in the center of screen.
6- A new screen will pop up then asking for the Passcode, enter: 0000 and press OK.
Your New Bluetooth Headset should now be linked to your Finesse. : )
2/20/2010 7:50:05 PM • Samsung WEP350... • Answered on Feb 20, 2010
Lost instructions for how to get my cell phone
1 Enter Pairing mode.
• Turn off your headset and press and hold the Multifunction
button until the blue indicator light remains lit
after blinking.
• If you turn it on for the first time, it proceeds into Pairing
mode immediately.
2 Search for and pair with your phone according to your
phone’s user guide. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will
flash 10 times rapidly before entering Standby mode.
• If the blue indicator light remains lit, retry pairing.
Pairing with your Bluetooth phone
When the headset and the phone are paired, the
headset attempts to reconnect automatically each
time it turns on. Otherwise, press the Multi-function
button to reconnect.
USER GUIDE
1/3/2010 12:16:08 PM • Samsung WEP350... • Answered on Jan 03, 2010
MY LG TONE HBS-730 stuck on incorrect pin i have samsung mobile
Here are some steps you can try: Reset the Headset: Turn off the headset. Press and hold the REW (rewind) button and the PLAY/PAUSE/STOP button simultaneously for about 5 seconds until the LED indicator flashes purple. The headset will reset, and you can try pairing it again. Pairing with Samsung Mobile: Make sure your Samsung mobile's Bluetooth is turned on. Slide the power switch on the LG HBS-730 to the "ON" position. The LED indicator on the headset will be solid blue, indicating it's in pairing mode. On your Samsung mobile, go to the Bluetooth settings and search for new devices. Select "LG HBS-730" from the list of devices. If prompted for a passcode, enter "0000" (four zeros). Once paired, you'll hear "Your headset paired." Check Battery Level: Press and hold the VOLUME DOWN button for 1 second to check the battery status. The audible alert will indicate the battery level (high, medium, or low). Charge the Headset: Connect the charger to the headset. While charging, the LED indicator will show a solid red light. When charging is complete, the LED indicator will turn off. Remember that the headset will automatically turn off if not paired within 3 minutes. If these steps don't resolve the issue, refer to the HBS-730 User Manual for more detailed instructions.
4/20/2024 10:44:15 PM • Samsung Radio... • Answered on Apr 20, 2024
Remote control for my vr headset will not sync up with my samsung ace phone
Both volumes buttons should be press at the same time and check out all settings before starting a https://mybestvrheadset.com/how-to-make-a-vr-headset-without-lenses
5/5/2021 7:05:05 PM • Samsung Radio... • Answered on May 05, 2021
2answers
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
11/18/2019 10:42:38 AM • Samsung Radio... • Answered on Nov 18, 2019
How to program a Samsung tv remote AK59-00149A
https://www.manualslib.com/download/436713/Samsung-Bd-F5100.html From above link down load manual and see instructions on page 13 of this manual, it will solve your problrm.
5/13/2019 7:46:09 AM • Samsung Radio... • Answered on May 13, 2019
Samsung giga Bluetooth stuck in waiting mode
Try disable bluetooth and switch off for 5 mins and then back on and enable bluetooth.
10/5/2018 8:08:33 PM • Samsung Radio... • Answered on Oct 05, 2018
How do you charge a Samsung wep500 without the Cradle
get another cradle. It cannot be done. CrackBerry com review of Samsung WEP 500
3/30/2018 3:28:48 AM • Samsung Radio... • Answered on Mar 30, 2018
Samsung WEP350 Bluetooth Headset Red Logo
21 questions posted
Top Samsung Radio Communications Experts
ZJ Limited
ZJ Limited
Jean Thiebaux
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Radio Communications
Most Popular Question
find
  • Radio Communications
