20 Most Recent Jabra Bluetooth Headset - BT2070 Questions & Answers
my jabra handset is not connecting with my blackberry 9530
Jabra Bluetooth... | Answered on May 30, 2012
Put your headset in pairing mode right before trying to pair it with your phone. In order to do it, start with it turned off. Then, press and hold the on/off button for some 5 seconds, until the indicator light is steadily lit (it will flash as it was being turned on, but don't release the button at that phase). It will be kept in pairing mode for a couple of minutes. Within that time span, bring your phone and headset close to each other and make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes).
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Anyway, please, let me know if I can assist you any further.
Regards,
Carlos
Jabra Bluetooth... | Answered on Oct 05, 2011
Put your headset in pairing mode right before trying to pair it with your phone. In order to do it, start with it turned off. Then, press and hold the on/off button for some 5 seconds, until the indicator light is steadily lit (it will flash as it was being turned on, but don't release the button at that phase). It will be kept in pairing mode for a couple of minutes. Within that time span, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes).
Regards,
Carlos
Jabra Bluetooth... | Answered on Sep 25, 2011
No, it isn't actually charging, it's just the light on indicating that it's attached to the charger. The actual 'bluetooth' guts are probably fried due to the water damage. Electronics and water do not mix. You'll need to buy a new one as it will be much cheaper than sending it in for repair.
Jabra Bluetooth... | Answered on Sep 21, 2011
Have you already tried to put your headset in pairing mode first? Anyway, in order to do it, start with it turned off. Then, press and hold the on/off button for some 5 seconds, until the indicator light is steadily lit (it will flash as it was being turned on, but don't release the button at that phase). Then, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Regards,
Carlos
Jabra Bluetooth... | Answered on Aug 19, 2011
Turn off the headset.
Hold the call/power button on the headset to make it discoverable.
Add it from your LG.
Use pin 0000.
Jabra Bluetooth... | Answered on Jun 13, 2011
The pass key is 0000. Check out the video here At Jabra. Hope this helps Fix Ya up.
Jabra Bluetooth... | Answered on Jun 07, 2011
The default password on all Bluetooth headsets is 0000. Should work. try that.
Jabra Bluetooth... | Answered on May 20, 2011
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Jabra Bluetooth... | Answered on May 01, 2011
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Jabra Bluetooth... | Answered on Apr 30, 2011
You can buy a bluetooth usb adapter and make your pc bluetooth enabled. I bought an I/o gear blue tooth adapter for $ 2.58 and it allows me to pair up my headset to my pc and I can go up to 500 ft away and hear perfectly.
All you need are 2.0 usb ports (high speed)
the adapter can cost up to $ 20 but it works and boy is it worth it!
Jabra Bluetooth... | Answered on Apr 20, 2011
Jabra Bluetooth Headset - BT2070 Logo
Popular Tags
73 questions posted
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Robek Thirtysix
Robek Thirtysix
Level 1 Expert
Mosaub Al Masri
Mosaub Al Masri
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Jabra Radio Communications
Most Popular Question
get
  • Radio Communications
