20 Most Recent
Jabra BT2050 Bluetooth Headset Questions & Answers
Jabra BT2050 Bluetooth Headset not found on cell
Try pairing it again. Make sure Bluetooth is enabled on phone, turn the BT2050 on by pressing and holding the side power button. Then, press and hold the center (round) button for at least 10 seconds (light will stay solid and it is now on pairing mode). Follow instructions on your phone. Hope this helps.
How to get Jabra BT2050 in pairing mode?
Press and hold the center round on/off button for 10 seconds to put Jabra BT2050 into pairing mode. Type in pin "0000" when the BlackBerry 8520 detected the bluetooth headset, then the two should be paired. Hope this help.
Joseph
I bought a jabra bt 2050...i cant get the led
Try to press and hold the center on/off button for 10 seconds, this will put the Jabra BT2050 into paring mode.
Assumptions made:
1) The BlackBerry is Bluetooth enabled.
2) The Jabra BT2050 is fully charged.
Hope this help.
Joseph
I purchased the Jabra BT2035
you need to intorduce again the jabra blutooth to your device. deleting jabra from the list make it forget the connection.
set your jabra to find mode by pressing the poer button for more than 5 seconds wait to blink, and find it using your device. it will again ask for a passcode and it will connect afterward.
How to get new batteries for jabra bt2050
Unscrew the small screw in the center of the Jabra's body.
Slide the body to the left until it slips off.
Unclip the existing, old battery.
Clip the replacement battery into place.
5
Replace the cover and the screw that held it down with the screwdriver.
- You must charge the jabra headset's battery and go through an easy setup process before use.
