20 Most Recent
Konica Lexio 70 35mm Point and Shoot Camera Questions & Answers
Is Konica Revio KD-420Zstill usable
If undamaged, with a fully-charged battery and the correct recording media - probably.
This answer also applies to your other queries, although as it was last produced in 2004, you will be unlikely to be able to obtain a new one.
I cannot get my konica
Hi
the following memory types are supported byt your camera
SD (Secure Digital) Memory Card / MultiMediaCard (MMC) / Memory Stick / Memory Stick Pro
Do you have a card reader on your computer? We could format the card on the computer and then see if it works with the camera.
Can you tell me the size of the sdcard?
To format the card on your computer plug it into the reader, open my computer and find the card from there, ones you have found the right one from my computer right click and select format, Try formating the memory card to fat 12 or 16 and then when the format is complete insert it into your camera again.
(turn off the camera, insert the card, turn the camera on)
If the memory card still doesn't work plug it to the computer again and this time format it to fat32.
If this ia new sd card with alot of storage do you have a smaller card that already works on the camera?
Camera does not switch on
OK Here's the problem and the fix ................... After removing the front cover (six screws) and carefully removing it you will find that the front thin metal cover has a plastic inner section that contains the slider mechanism. The plastic bit is attached to the metal cover by two or three strips of double sided adhesive tape and is a real b*st*rd to get apart, but this is what you have to do, so gently but firmly prise them apart, I raised one end with a watchmakers screwdriver and then used a 20 thou feeler to "cut" through the tapes, which can be reused on reassembly.
Once apart it is obvious how the thing works and the problem was seen to be a return spring that had slipped out of position. Using a large needle this was repositioned so that the cam returned to the "off" position. Reassembly is simply a reverse of this procedure.
The malfunction was caused by a few grains of Australian sand (last week only!) jamming the cam causing extra stress on the spring which jumped out of it's position - and here I mean a spring that is at best only three mills long! A magnifying glass helps.
If you can't work to very fine detail better leave it alone .................. All the best
Jim
Slight play or looseness with
remove the camera battery for a while to reset the system..
if you had a problem on the lens, this would be a hardware problem and you need to bring to authorized center.
let us know more info regarding this problem. an additional input is greatly appreciated...
thanks
Konica Minolta 7D
It was nice to be able to help another. I noticed the post that her 7D would not turn on. It seems just before Konica Minolta stopped there camera business they had a serious problem that was not passed around or corrected. Your expensive 7D camera does not turn off when you take off the lens. When you put another back on while the camera is still on it will fry out a circuit board or sensor. That will cost ya about $300.00 to repair.
I thought I would let her know how to prevent it from happening again. I have done this twice now. My 7D is in repair. I figured out why it does that. Wish they could have told me.. Had to learn the hard way. Also wish they could put a better resister in the camera or have an auto shut off switch. Would make more sense ..
How do you turn on Digivue1.3? Has new batteries and used a while ago but pressing 2 button (Mode, Set) do nothing.
This is going to take patience and maybe the user guide. To turn on the Digivue 1.3, follow these steps:
Connect to Your PC:
Connect the standard USB cable (supplied) to a free USB socket on your PC.
The end of the USB cable should be connected to the socket on the back of the USB digidock.
Important: Do not connect any of the cabling provided with the Digivue before commencing the software installation.
Install DigiConnect Windows® Software:
Insert your Digivue into the docking station.
If you are connecting for the first time, a Red LED will display in the Activity Window of the Digivue.
Insert the CD provided into your optical disk drive. It will run automatically, and a dialog box will appear.
If the autorun feature is disabled on your system, browse to the disk using Windows® Explorer and double-click Setup.exe.
If you have a multilingual version of Digiconnect, you will be prompted for your language. Select from the list and click "Next."
Accept the terms in the License Agreement and proceed with the installation.
Choose the folder for software installation (default is the standard location for Windows® programs).
Click "Install" to begin the installation.
Leave the box labeled "Launch DigiConnect" ticked and click "Finish."
Wait for the Red LED:
Wait until a RED LED appears in the activity window of the Digivue.
You may now proceed with the next steps.
If you encounter any issues during this process, refer to the detailed instructions in the Digivue User Guide on page 9
4/1/2024 1:04:02 PM •
Cameras
Answered
on Apr 01, 2024
Which is the best weding photographer in ernakulam
Here are some highly regarded wedding photographers in
Ernakulam, Kerala:
- Maks Wedding Photography:
- Located inChelad, Kothamangalam, Kerala.
- Specializes inwedding photography and videography.
- Contact:099478 23133.
- Facebook Page
- Lumiere Wedding Company:
- Based in Ernakulam, Kerala.
- Their crew beautifully captures emotions during the D-day, creating elegant pictures that will remain etched in your heart forever.
- They cover weddings not only in Ernakulam but also in UAE, Malaysia, and other parts of the globe.
- Contact:099951 48014.
- Website
- Euforia Wedding Photography:
- Located atUzhinjelil Tower, Convent Rd, Ponnurunni, Vyttila, Kochi, Kerala.
- Offers candid and artful wedding photography packages.
- Cherish the vibrant traditions and colors of your Kerala wedding with their skilled team.
- Contact:090481 90403.
- Website
- Dakshin Wedding Services:
- Exclusive wedding photography and videography company covering events across South India.
- Address:Js 5, 5th Floor, Heavenly Plaza, Kakkanad, Edappally, Civil Line Road, Ernakulam, Kerala.
- Contact:070123 90551.
- More Information
Remember to explore their portfolios, discuss your preferences, and find the photographer whose style resonates with your vision for capturing your special day! These companies use teams. It is difficult to pick out an individual photographer but perhaps you might find what you are looking for at the Lumiere Wedding Company. That company stands out among the four I mentioned.
3/15/2024 10:38:43 AM •
Cameras
Answered
on Mar 15, 2024
