20 Most Recent Panasonic HDC-SD20 High Definition Camcorder Questions & Answers
This could be contamination either on the lens or on the sensor.
Panasonic... | Answered on Jun 13, 2017
If you have the CD with HD Writer AE, justfollow the steps below:
1. Go to the Administrator account and download the update software from: http://cnc.asp.hi-ho.ne.jp/cnc/global_cs/software/win7/Setup.exe
2. Insert the CD-ROM with the HD Writer AE1.0.
3. Double click the Setup.exe you just downloaded, and follow the procedure.
A free alternative to backup videos from camcorder to hard drive without HDWriter AE on Windows 7: Aunsoft Final Mate.
Panasonic... | Answered on Jun 10, 2015
Maybe you get one from one of your friends, who may have Panasonic camcorder too. Otherwise, it is impossible to install HD Writer AE without the CD.
What are you trying to do with HD Writer AE?
I had success with steps below
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download sd card recovery software, recommended Asoftech Data Recovery (simply because i was using it and it worked) with link below
SD card recovery software
4. Install and open the data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your files.
Panasonic... | Answered on Aug 05, 2013
Just had this problem on my mac with the same camera. Plug everything up as you had before. Iphoto's should open up but you won't see anything. Close Iphoto's and then open Imovies. Click on file and then import from camera. Then follow the instructions. Hope this works for you.
Panasonic... | Answered on Jul 22, 2012
I have same problem. I have Panasonic HDC-TM20 video camera. It came with HDWriter ae 1.0 software. I have ACER alptop, running XP. Everything was running fine for months, but now I cannot transfer from the video camera to the hard disk on my computer. It attempts to do it, but then it just does nothing for ages. CPU usage shoots up high. When I kill the application, it does die, but process continues so I need to re-boot mt laptop before I can load it again. Is these any one out there who has resolved this issue?
Panasonic... | Answered on Nov 06, 2011
Hi There, few things to follow:
1. Install an update from Panasonic website at www.panasonic.net (This is a pack of 4 files you need to download 1 by 1) 2. Plug your camcorder to the back usb and not in the front port. 3. Disable your Resident Shield on your anti-virus.
Done!
Panasonic... | Answered on Jul 22, 2011
Did you install HD Writer AE under the Administrator account? Some software would require the Admin to run.
If you would like to backup the files from camcorder to PC, just copy and paste between the drives. It shall be straightforward, as the cam could be recognized as a device when connected via USB 2.0. Alternatively, you can try Aunsoft Final Mate to backup the videos.
Panasonic... | Answered on Apr 19, 2011
this is not an issue cause if it works on 2.0 it works on 1.0 too ...the other way around is not always a working solution ..
The issue is that the USB connection is for using it in streaming and such ..and you will have to make a firewire connection for download ..If you installed the driver ..and the camera has a firewire connection use it ..and the hdd will be see on my computer as a drive ..or you will have to use a video manager to import from device ...(you can use the windows movie maker...and import from device feature.)
try it and let me know ..If the camera came with a manager software ...install it too and use it ..
Panasonic... | Answered on Dec 31, 2010
I called panasonic...they offer a replacement for 13 bucks! Geez
Panasonic... | Answered on Apr 19, 2010
Look in the manual - often helps
Panasonic HDC... | Answered on Jan 05, 2018
Panasonic HDC-SD20 High Definition Camcorder Logo
29 questions posted
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
HDC Panasonic
  • HDC Panasonic
Most Popular Question
accidently deleted files sd card hd
  • Video Cameras
