20 Most Recent
RCA EZ300 Camcorder Questions & Answers
Its asking for the sd card to be unlocked and it
Hello
OK,
if the memory card itself is locked, you might sometimes get this error
code. All you need to do is to take out the memory card and switch the
lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If
you open you sd slot and look inside with a sharp light , you should be
able to see on the left side of the slot there is a little copper or
spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary
to popular belief ,the little tab on the sd card is not an electronic
switch and does not physically influence the card operation itself. If
you put a locked card into a camera without a sd lock switch , you would
still be able to use the card normally.
It is incredible
difficult to fix this switch because of space limitations in the sd
card. Look into the sd slot and if you can see the switch , use a needle
to pull the little tab down toward the base of the camera by about 2mm
or until it works being careful not to bend it.
If this does not
resolve your problem , there might be a short in the switch circuit and
the camera will need to be disassembled to resolve this error. This
should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
9/30/2010 9:36:12 AM •
RCA EZ300...
Answered
on Sep 30, 2010
Locks up
Thanks for using Fixya.
(i) Try to delete some items from your device.
(ii) Take out your memory card, battery and then again put them back.
(iii) Scan it with any antivirus.
If the problem still exists, you will need to take your device to the service center for possible internal faulty.
Good Luck and have a nice day.
5/19/2010 7:07:16 PM •
RCA EZ300...
Answered
on May 19, 2010
RCA CC604 VHCS Camcorder. My old camcorder won't record?
Question edited into written English with punctuation.
The lens isn't black, the viewfinder is black. Connect it to a television or computer and see if playback and live recording is working. In that way you know the optics and the electronics are working. The viewfinder is a small LCD display screen with a magnifying glass in front of it. Take it to your local camera shop, they will know someone that still repairs these camcorders.
I was hoping to find a free PDF manual as I wondered if there is a switch or a setting to turn OFF the viewfinder?
https://www.google.com/search?q=RCA+CC604+VHCS+Camcorder+manual
2/11/2023 11:54:21 PM •
RCA Video...
Answered
on Feb 11, 2023
RCA CC433 will not record or play back tapes
You can first check for any debris in the video tape player and double check that no settings are stopping the tape from playing (ie a stuck rewind button) . Otherwise, please use the services of geeksquad/bestbuy to refurbish your vcr player. You might also check out BandH (?) video to see if they can refurbish your video tape player.
Thank you.
11/18/2022 6:23:14 AM •
RCA Video...
Answered
on Nov 18, 2022
Need a manual for rca camera
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
1/2/2017 10:43:55 PM •
RCA Video...
Answered
on Jan 02, 2017
