20 Most Recent
Sony CRX880A CD-RW/DVD-ROM Combo Drive Questions & Answers
My Sony CDRWDVD CRX880A ATA
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
My Sony Combo Model CRX320AE
Try a different CD/DVD
1. First we must determine if the cd/dvd or the cdrom itself has a defect
2. Try at least 10 cds to test on your cd/dvd player
Try Deleting LowerFilters / UpperFilters
To do this follow the steps below:
1. Click Start -> Run (for XP) or Start Search (Vista) or search for programs and files (Windows 7)
2. Type Regedit
3. Click on the plus sign beside HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
4. Under Class Click on the Folder {4D36E965-E325- ....} (note that the alpha numeric numbers are quite similar we only need ....65)
5. Look for UpperFilters and Delete it
6. Look for LowerFilters and Delete It
7. Restart the computer
If it did not work try
Replacing the IDE cable
1. Open thechassis of the computer (refer to your computer manual)
2. Try disconnecting and reconnecting the gray cable that looks like a belt at the back of the computer
Drive not recognized driver missing or currupt
a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
Sony crx880a cd-r/rw/dvd-rom drive won't do
Please go ahead and click on start > in start search type in device manager {(in vista ) in case of xp right click on my computer > properties > hardware > devicemanager}.
In device manager click on the + sign beside the cd- dvd > then right click on the driver and uninstall it .
Then in start search type in regedit {(for vista ) for xp in run type in regedit}
Look for some thing like
HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then on the right hand side look for something like upper and lower filters and delete the upper and lower filters....
Restart the notebook . It will help
My cd/dvd sony crx880a drive stopped working
- Click Start , and then click All Programs.
- Click Accessories, and then click Run.
- Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
- In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
- On the Edit menu, click Delete.
- When you are prompted to confirm the deletion, click Yes.
- In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further.
- Exit Registry Editor.
- Restart the computer.
Microsoft Windows XP loadTOCNode(2, 'resolution');
- Click Start, and then click Run.
- In the Open box, type regedit, and then click OK.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. G
Sony MHC-vx888 turn volume up sound disconnect
the capacitors in side on the amp have gone weak. it has noticed the fault and is telling you. check the capacitors look for any sight of problems look for the end being popped up and brow-black gunk on the board around them tackie to the touch and change them. also give the boards a good clean out using a new paint brush sweep the dust out.
10/20/2013 2:05:40 AM •
Sony CRX...
Answered
on Oct 20, 2013
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
