20 Most Recent eMachines ET1161-07 Desktop PC Questions & Answers
http://www.pcityourself.com/building/frontPanelConnections.php
FRONT PANEL CONNECTIONS IN GENERAL.
IS THIS WHAT YOU MEAN.
eMachines... | Answered on May 18, 2015
A virus check might not get all malware. Download Malwarebytes free and do a scan with that. Check the add-ons installed in you browsers and get rid of superfluous or strange ones. Use msconfig to check which programs are loaded at start up. Uncheck unnecessary or suspicious ones. Good luck.
eMachines... | Answered on Feb 07, 2015
This might be a dodgy stick of memory or memory slot. If you have more than 1 stick of memory, see what happens if you just use variations of just 1. Maybe try disonnecting all drives except the one you boot from. And, not sure exactly what you mean by works once and how far it gets after removing the CMOS battery. But does it get far enough to boot from a cd? If it does, try getting hold of a AVG rescue disk this will run a pre-boot virus check which may clear the problem if you're lucky. Obviously you would have to use a friend's machine to burn the disk. Unlikely, but could be a failing powers supply. Borrow one and try it instead. Otherwise, it really sounds like a terminal motherboard issue to me. Godd luck.
Buy a hard drive external usb case,they are around 30 pound,take out the hard drive from your pc and put it in the external case and use another pc/laptop to get all your valuable files off the drive that wont boot.
eMachines... | Answered on Nov 07, 2014
try changing the monitor, if this fails the video card on the computer needs changing.
eMachines... | Answered on Sep 16, 2014
That's easy. Open the side panel of the CPU. Locate the battery on the motherboard. Pull it out. Place a fresh one.
eMachines... | Answered on Aug 11, 2014
Are you expecting a folder or program called 'e machines'? Many machines come with manufacturer branded bloatware, and many users uninstall this stuff to make their machines run better.
eMachines... | Answered on Jul 02, 2014
yes there is but you have to but HDMI card.
eMachines... | Answered on Mar 17, 2014
TRY WITH A OTHER PSU.
eMachines... | Answered on Sep 15, 2013
Most likely a hard drive problem. When you get the flashing cursor, it indicates a lack of an accessible Operating System. But, if the drive was good you would get a boot failure indication. I would try booting with an XP disc and look for the HDD (or try F2 when you boot) to get to the BIOS and look for the drives there.
eMachines... | Answered on Sep 03, 2013
A) Power On switch is no good
B) Power Supply is no good
Do you wish to perform the simple test, to see if the problem is the Power On switch, or Power Supply?
If so post back in a Comment.
Also, IS it an eMachines ET1161-07 Desktop PC?
Don't want to 'rattle my lips off', if it's a different computer.
http://www.directron.com/atxswitch.html
Post back in a Comment.
Regards,
joecoolvette
eMachines... | Answered on May 07, 2013
Need more information. Are you using VGA, HDMI S-Video?
eMachines... | Answered on Apr 29, 2013
hi ...
whn you say the computer boots up in safe mode..
in this list you should have an option called as load windows normally (similar to this)
use the arrow keys and select it.. and then press enter and please do let us know what happens..
it should ideally work...and if it boots up to your desktop please investigate..
eMachines... | Answered on Apr 11, 2013
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
eMachines... | Answered on Nov 19, 2012
eMachines ET1161-07 Desktop PC Logo
77 questions posted
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
E eMachines
  • E eMachines
Most Popular Question
emachines et1161 07 freezes e logo only
  • Computers & Internet
