20 Most Recent Electrolux EIFLW55I Washer Questions & Answers
I have a Electrilux IQ
The only way is to take it off and check
10/11/2017 7:15:57 PM • Electrolux... • Answered on Oct 11, 2017
2answers
HALFWAY THROUGH THE WASH IT STOPS AND IT SAYS ITS WASHING WITH THE REMAINING TIME LISTED BUT ITS NOT WASHING
Hi Benny, this is Z. Thank you for your post! From what you have described it sounds like you either have a communication problem with the control board or timer. Let's attempt resetting your washer. You can do this by unplugging it or flipping the household circuit breaker off. It is good to wait roughly ten minutes and then turn your washer on. Select a normal cycle and verify if your washer does complete a cycle. If your washer will not operate, then at this point I would recommend contacting a professional to move forward accurately.
6/30/2015 12:39:25 AM • Electrolux... • Answered on Jun 30, 2015
Washing machine Eletrolux EWT 705, suddenly power off while washing. Unable to turn on the washing machine after that.
Typically this sort of issue is caused by a faulty timer
2/4/2015 11:59:04 AM • Electrolux... • Answered on Feb 04, 2015
Eletrolux door lock
Good Morning Friend, I understand you are having trouble with the door lock on your Electrolux washer, model# EIFLW55I. I will be more than happy to assist you. In order to better assist, I will need the model number of your washer. Typically, this will be located around the edges of the opening, where the door meets your appliance. Looking forward to hearing from you. -WP-
6/12/2014 1:07:48 PM • Electrolux... • Answered on Jun 12, 2014
Which compartment for bleach?
Good Morning Friend, I understand that you want to know which opening in the dispenser is for bleach on your Electrolux washer, model# EIFLW55I. The compartment where you will put bleach will be labeled "Liquid Bleach", and will also have a symbol of a triangle with the letters "CL" inside of it. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful. -Best Regards- WP
6/12/2014 12:52:52 PM • Electrolux... • Answered on Jun 12, 2014
2answers
When pushing the soap dispenser
Re: Soap dispenser door not opening properly...(in case you still need to know)
You might want to use a small mirror (and flashlight) to see where the the spring assembly fits. Turn the rod facing towards you with the flat side up. It attaches at the rear, top left corner, near a small opening on the back wall (shaped liked the assembly). Fits into the "grooves". Apply enough pressure and you will feel it snap into place.
4/15/2014 3:40:05 AM • Electrolux... • Answered on Apr 15, 2014
E32 and E21 Error Codes
I had the code E21 error (not draining) on my 2012 Electrolux EWFLS70JTS0, which I'm guessing is similar to a Frigidaire Front Load Washer. After reading about the potential causes being related to drain or pump obstructions, I decided to try forcing compressed air into the drain hose at the rear of the washer to see if I could push out whatever got into the system. So I moved the washing machine out from the wall, and pulled the drain hose out from its wall inlet. No disassembly required. Then I placed the trigger air nozzle from my compressor into the drain hose that's connected to the back of the machine, and held it in place with my hand so that most of the air pressure would go up the hose and into the machine. Once I pulled the trigger to start the air flow it only took a few seconds to see bubbles appearing in the washer's tub. At that point it seemed any obstruction was now pushed out (where it went, I'm not sure. Somewhere in the standing water in tub I suspect). I suppose it would be just as effective to use a garden hose with water (if you don't have an air compressor), but a little more messy. Anyway, as soon as I put it in "quick wash" mode (which starts with a drain cycle), it drained fine. 100% problem solved! No more error code. And no repair bill!. I just hope that whatever was restricting the drain flow does not find its way back into the system again. It's been a couple of days and so far, so good.
9/29/2013 9:30:33 PM • Electrolux... • Answered on Sep 29, 2013
Water will not drain. sewer line is not pluged.
Hi agnes! Washing machines, including those built by Frigidaire, have internal pumps. These pumps help drain out the water from the washer tub between the wash, rinse, and spin cycles. If the pump is damaged or the pump pulley system is frozen/stiff, the water can become trapped in the washer tub. In both cases, the pump assembly needs to be replaced. You can check by looking for a few signs that a pump is dying or already dead. 1 Start the washer and wait for the washer tub to fill with water. If you do not hear water or hear a motor whirring, the washer motor may be dead. 2 Open the washer lid in mid-cycle. Note whether or not the inner tub is still spinning around. The inner tub is the inside surface of the washing compartment with many holes for water draining. If the tub is not spinning but the motor is running, it is possible the pump is dead. Check the pump pulley by removing the pump from the washer and trying to rotate it by hand. If the pulley doesn't turn freely and is frozen or stiff, replace it. Also, if the agitator is moving but the tub isn't, this is a sign the pump is dying. For front-loading washers, do not attempt to open the door mid-cycle. Look through the glass door. If there is enough water to come up against the door, the pump is malfunctioning. 3 Wait for the washer to finish its cycle. Open the unit. If water is still in the tub, the pump is likely dying or dead.
9/4/2013 7:28:20 PM • Electrolux... • Answered on Sep 04, 2013
Running the EIFLW5551 causes RF interference with my computers. Is there a way to stop fix this problem? Vic
Hello Victor,
Hello Victor,It is recommended that a filter is placed on the power supply line of the unit. It is also recommended that you consult an Electrician to ensure this is done correctly.
3/27/2013 3:18:44 PM • Electrolux... • Answered on Mar 27, 2013
Sewer odor when draining
Please check this link for tips for maintenance of your machine. click this link to keep it odour free.
1/12/2013 10:25:32 AM • Electrolux... • Answered on Jan 12, 2013
Cannot open the door of electrolux perfect balance washing machine
Hello Nina DeLuca - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
1/7/2013 6:48:36 PM • Electrolux... • Answered on Jan 07, 2013
Why do i have 88:88 flashing on my washer (model EIFLW55HIW0)
Unplug the unit for 30 mins. then plug it back in.
10/22/2012 6:15:53 PM • Electrolux... • Answered on Oct 22, 2012
Electrolux EIFLW55I Washer Logo
60 questions posted
Top Electrolux Washing Machines Experts
David Shaub
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Washing Machines
Most Popular Question
running eiflw5551 causes rf interference
  • Washing Machines
