20 Most Recent AudioBahn A2801Q Car Audio Amplifier Questions & Answers
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
AudioBahn A2801Q... | Answered on Aug 24, 2014
Hello... I can help you with this question. This particular amplifiers specifications are as follows:
  • 200 watts x 2 @ 4 ohms stereo
  • 280 watts x 2 @ 2 ohms stereo
  • 560 watts x 1 @ 4 ohms mono
    These specifications are RMS power, which would mean continuous "real" power output. Hope this helps!
    20 year car audio/video installer
    Bay manager
  • AudioBahn A2801Q... | Answered on Mar 15, 2011
    No it is not. You will melt that amp trying that. It is only good for 4 ohms mono and two ohms stereo.
    AudioBahn A2801Q... | Answered on Aug 21, 2010
    audiobahn.com under tect support you can download manuals and get wiring diagrams for free
    AudioBahn A2801Q... | Answered on May 11, 2010
    square port (slot loaded) vented box tuned at 33 - 38 hz is the loudest deepest bass you can get
    AudioBahn A2801Q... | Answered on Jan 10, 2009
    If you used a wire harness to connect with the factory setup, try running the power wire to your fusebox. Find a fuse that is only live when the car is running and insert the wire with the fuse.
    AudioBahn A2801Q... | Answered on Aug 29, 2008
    Audiobahn A2801Q
    Product Description:
    Class A/B MOSFET Circuitry
    Volt Meter With Blue Illumination
    PWM MOSFET Power Supply
    Double Sided Glass Epoxy Circuit Board
    THD: 0.02%
    S/N Ratio: >100dB
    Frequency Response: 10Hz - 40KHz (+/- 1dB)
    Variable 18dB Hi-pass Crossover: 90Hz - 750Hz
    Variable 18dB Low-pass Crossover: 30Hz To 120Hz
    Bass boost @ 45Hz: 0/18dB
    Subsonic Filter: 20Hz to 50Hz
    RCA Throughput Connections
    3-way Protection Circuitry: Thermal, Short Circuit and Overload
    Cooling Fan
    Cobalt Blue Illumination
    High gloss Chrome Plated Finish
    Nickel Plated Block Terminals
    Dimensions: 2"(H) x 12.75"(W) x 15.5(D)
    1-year warranty
    AudioBahn A2801Q... | Answered on Jan 04, 2008
    Is the protection light lit?
    AudioBahn A2801Q... | Answered on Nov 25, 2007
    Hello William Novelli, if it would be compatible, but you should control the order of the connections, they can vary
    I send you the link to download the manuals of both models and compare the connections, if you find it complex, consult a specialized technical service
    I hope you find it useful
    Regards Franco Dosil
    Hola William Novelli, si seria compatible, pero deberas controlar el orden de las conexiones, pueden variar
    Te envio el link paravque descargues los manuales de ambos modelos y compares los conexionados, si te resulta complejo, consulta con un servicio tecnico especializado
    Espero te resulte util
    Saludos Franco Dosil
    https://manualmachine.com/audiobahn/aeq7/18414-user-manual/
    https://manualmachine.com/audiobahn/aeq8/18268-user-manual/
    https://www.manualslib.com/manual/211695/Audiobahn-Aeq6q.html
    AudioBahn Car... | Answered on Sep 13, 2019
    as your sub is only rated to 400w rms simply connect the sub to either a or b channel outputs you may wish to use an rca splitter before the amp to feed both left and right audio channels into a single channel on the amp. WARNING connecting both channels on the amp to the sub will overload the sub and possibly blow it up so i highly recommend not doing so.
    AudioBahn Car... | Answered on Jun 03, 2018
    i was not able to locate a manual but i did find some interesting information that hopefully may help,
    The AudioBahn AW1000X Car Subwoofer Features: dual 4-ohm voice coils, non-pressed pulp cone, huge foam surround, frequency response 23-500 Hz, power range 50-600 watts RMS (300 watts per coil), peak power handling 1,200 watts, sensitivity 91.1 dB, top-mount depth 5-1/4" ,sealed box volume: 0.4-.95 cubic feet, ported box volume: 1.632 cubic feet.
    i'd need more info but from what you've stated, sorry to break it to you but it sounds likely you've incorrectly wired you speakers and blown your amp. this will prove no doubt an expensive mistake and learning exercise.
    AudioBahn A2801Q Car Audio Amplifier Logo
    14 questions posted
    Top AudioBahn Car Audio & Video Experts
    Dalynn Turner
    Professor_V
    Professor_V
    Alphanso Tee
    Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
    View Most Popular
    • AudioBahn Car Audio & Video
    Most Popular Question
    amp a2801q
    • Car Audio & Video
