20 Most Recent
Draytek Vigor 2950 Router Questions & Answers
Status firmware damage
I've run across this and found that a update would install but not work, then at that point the restore to default would. The unit worked fine for 2 years after but would never allow itself to upgrade after that. Of course the proper 'paid' solution was to send it in or replace.
I dont know if the cmos is actually at fault or the images are being corrupted. Tech support seemed to be reading off of a script and were pretty useless then, (Maybe they have improved). About the only useful advice I can give is based on my experience with this. If you can get it to work it may be stable but if it is a critical router I'd replace it. Not a fix but just some experiences with it.
Got a problem with a
Strange I have had exactly the same issue today with a 2820 that hasn't given 1 minute of trouble before FYI running Firmware version 3.3.3
Draytek Vigor 110 modem
There is no default username or password to access the Vigor routers. Reset the router to clear any previous settings from its memory. Default IP Address is http://192.168.1.1 Manuals and firmware is available from the device maker.
4/16/2010 12:49:48 AM •
Draytek...
Answered
on Apr 16, 2010
Vigor2910vg locked intoTFTP mode
Try to Hard reset the router before executing firmware update.
Press reset button and hold it for 1min. You to turn off the router and turn it on before updating the firmware.
Goodluck!!
10/5/2008 12:54:04 AM •
Draytek...
Answered
on Oct 05, 2008
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
