20 Most Recent Belkin F5D7234-4 Router Questions & Answers
Hello, friends, I understand this is a common problem with the Belkin router. Don't worry just follow my instructions and you will be helped Restart = take out the power cable and wait for 20 sec then plug it back
  • Restart the modem (cable/DSL modem)
  • Now restart the router and computer also and wait for 2 min.
  • See if this gets you Belkin wireless router online.
if it does not work then we have to try these steps -
Fix Belkin Router -
  1. First, you need to unplug the Belkin wireless router from the modem and now connect the computer to your modem with a cable Just to see you are getting the internet.
  2. Now connect the modem to the router using an internet cable to the internet port(Ethernet port).
read more at Belkin wireless router is not working Get belkin router setup
Belkin F5D7234-4... | Answered on Oct 30, 2018
Your PSP does not support the WPS feature on the Belkin router. The solution is to turn WPS off. WPS can be disabled in the configuration program for your router.
You do not need WPS it is simply a protocol to make conection to some modern devices simpler.
Belkin F5D7234-4... | Answered on Sep 18, 2018
If you need any type of information (technical and non-technical) regarding Belkin Router. You may visit here Belkin Support Belkin Router Support Number 1 800 335 8177 Belkin Help. Here at this link, you will get all your answers regarding Belkin Routers.
Belkin F5D7234-4... | Answered on Sep 17, 2018
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Belkin F5D7234-4... | Answered on Aug 25, 2018
click here and read my various tips to get a clear idea about your question...
If you are having this issue then I will advise you to contact Belkin customer.
visit Contact Belkin Support Belkin Phone Number Belkin Tech Support
and get resolved
open the belkin outer interface by following this link below...
http://www.fixya.com/support/r4724899-configure_belkin_routers_without_install
goto "Mac address control" on the left side below "wireless" ...
Delete the Mac address or disable the feature and apply changes... Thats it...! u r done....!
http://download.cnet.com/1770-20_4-0.html?query=Belkin+F5D7234-4+Router&platformSelect=Windows&tag=srch&searchtype=downloads&filterName=platform%3DWindows&filter=platform%3DWindows go there they have options for drivers and software..
if your using lenovo and is an Ideapad Y series or a G series Laptop look for the program called lenovo readycom in the control panel add remove programs if you have XP and if vista go to control panel and look for programs and features this goes the same with win7 just uninstall Lenovo Readycom 4.0 or 5.0 and as well look for a program called network magic if that program is present then uninstall this as well then restart your laptop, try connecting again ^_^ happy surfing ..
Here is a link to Teleblend tech support.
http://support.teleblend.com/index.php?_m=downloads&_a=view&parentcategoryid=1
With my VOIP setup @ home, my path is as follows:
Modem -> VOIP Adaptor - phone
Ethernet out - router Wan input
Belkin F5D7234-4... | Answered on Dec 04, 2017
Go to http://setuprouter.com/router/belkin/f5d7234-4v5/login.htm and then follow the instructions following: Login to the Belkin F5D7234-4v5 Router and work your way down through the instructions.
Belkin F5D7234-4... | Answered on Jun 12, 2017
You will pobably need to reset the router back to factory state.
Below is a link to help with the prceedure:
Link:
http://en-us-support.belkin.com/app/answers/detail/a_id/30/~/setting-the-router's-administrator-password
Hope this helps....................
Belkin F5D7234-4... | Answered on Dec 06, 2016
MAC (Multimedia Access Control) addresses are unique sets of codes assigned to electronic devices that identify the devices on a network. MAC filters work by either allowing or denying only specific MAC addresses. MAC filters are a great security measure; however, if your network needs to be open to public or guests, or you're adding and removing devices often, then you should consider turning off MAC filtering.
EditMethod One of Three:
Wireless Routers (Windows)
  1. 1 Open the Command Prompt. You can access it from the Start menu, or by pressing ? Win+R and typing cmd.
  2. 2 Type .ipconfig and press? Enter.
  3. 3 Find your active network connection.There may be several connections listed in the readout, and you may have to scroll up to find your active connection.
  4. 4 Look for the .Default Gatewayentry. This is the address for your router. Write it down.
  5. 5 Open a web browser. You can access your router's configuration page from any web browser as long as your computer is connected to the network.
  6. 6 Enter the .Default Gateway address into the browser's address bar.
  7. 7 Log in with your admin account.Routers are protected with an admin login and password. Check your router's documentation or look up the model online to find the default login information.
    • If you can't figure out how to log in to your router, you can reset it by pressing and holding the Reset button on the back for about 30 seconds. After the router restarts, you will be able to log in with the default admin information.
    • Most default logins use "admin" as the username, and then "admin", "password", or a blank field as the password.
  8. 8 Open the "Advanced" section and look for "MAC Filtering", "Access Control", or something similar. Actually defining where the "MAC Filtering" section is located is very difficult, as the location and labeling is different for every router. Generally, you can find the "MAC Filtering" or "Access Control" settings in the "Advanced" section, though it may also be found in the "Security" or "Wireless Settings" sections.
    • Not all routers use MAC address filtering. Some router's limit access based on static IP addresses assigned to each device.
  9. 9 Disable MAC filtering. Again, the wording and location will vary depending on the router, but you will generally be able to select a "Disable" option to turn off MAC filtering.
    • This may be a checkbox, a button or a selection that you can make.
  10. 10 Save your changes. Click the "Apply" or "Save" button to save your changes to the router settings. Your router will apply the changes, which may take a few moments.
    • If you are configuring your router over a wireless connection, you may be logged out when settings changes are saved.
Belkin F5D7234-4... | Answered on May 15, 2015
Access it via its ip address. Google Belkin for their standard username and password and connect via browser to the router -you will need to obtain its ip address. Think it should 192.168.0.1
Belkin F5D7234-4... | Answered on Aug 02, 2014
i want my wi fi number change
Belkin F5D7234-4... | Answered on Dec 18, 2013
Reset the outer here is how
Belkin F5D7234-4... | Answered on Apr 17, 2013
You need to encrypt your wireless router to protect your Internet access fro unauthorized access.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Belkin F5D7234-4... | Answered on Feb 07, 2013
Mine has this problem also. Apparently this is related to the voltage circuit. If someone has the schematics or the solution please tell us.
Belkin F5D7234-4... | Answered on Jan 09, 2013
Belkin F5D7234-4 Router Logo
316 questions posted
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
connect
  • Computers & Internet
