20 Most Recent
Biostar P4M900-M7 Fe VIA P4M900 Socket 775 mATX Motherboard w/Video & Audio Questions & Answers
Driver p4m90 m7a
GOOGLE BIOSTAR HOME PAGE
different support for other countries so learn to google\
and not have me send you to USA site wrong.
I can not google for you , see? (complex yes)
use only their drivers
or MS
and no others. , as those are now infected.
XP is junk OS
drivers match os AND NO OS TOLD YET.
3WAY MATCH, BIOSTAR,+ DEVICE AND +OS.
5/17/2022 6:24:12 PM •
Biostar...
Answered
on May 17, 2022
Boot up problem...
please help me too i have same problem with my biostar g31d-m7 motherboard
6/22/2013 4:54:28 PM •
Biostar...
Answered
on Jun 22, 2013
I can not find driver
Here are all the drivers you'll need:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=314
5/15/2011 6:51:41 AM •
Biostar...
Answered
on May 15, 2011
I need the audio driver
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
1/24/2011 2:44:29 PM •
Biostar...
Answered
on Jan 24, 2011
I purchased a barebones kit with a Biostar
Yes it could be the motherboard but i would go back and check all the connections before you come to the decision that the motherboard is bad.
Check that you have your connections right on the front panel header, also check the connectors to and from the PSU (power supply unit)
Check that the motherboard support the bus speed of the memory (usually its 400MHz)
Try clearing the CMOS too which is a small plastic coloured jumper next to or near the motherboard battery.
Good luck.
8/1/2009 2:50:25 PM •
Biostar...
Answered
on Aug 01, 2009
New motherboard won't power up
First check your motherbord POWER pin it is in corner of motherbord.
Just short that 2 pin with screw driver .
Read on motherbord corner you can find pin for Power up.
also reconnect cable from psu to motherbord.
8/1/2009 2:50:22 PM •
Biostar...
Answered
on Aug 01, 2009
Biostar i945cm7b
best is noobs avoiding UEFI
and 945 is 2005 tech, not modern UEFI bios .at all
but do ask maker this.
but 945 ended there.
6/6/2022 1:34:56 PM •
Biostar...
Answered
on Jun 06, 2022
Mainboard Vestel 14MB02-03 no power
posted to computer repair help, PCwhat computer is this, not toldVestel 14MB02-03 (mobo labels useless)Vestel made this mobo under contract to an OEM PC maker,. like BIOSTAR? or who? not told really.Vestel does not sell PCs ! google shows no hits (zero). posted wrong PC model?ahhhhh coded words off mobo white painted silk screenssureI see one hit on that number alone and shows LAPTOP PC MOBOclearlyok , why post mobo models. and not real maker of PC laptop model, did you somehow lose the laptop casings.??>???????????odd odd post this is, like that. we fix PC by makers name and real models. not mobo codes. sorrythe model is on the bottom tab on laptops oldor in bios screen 1 toldnow and answer for laptops old. 1: big battery dead and worse shorted making PC dead, remove it run on AC power pack only,see it works.2: coin cell dead, sure it is that old replace it.3: any of up to 20 other modules inside shorted out.4: stuck in sleep mode dead, push power button for 10 seconds and release, runs now?5: LCD CCFL back lamps dead, use a flash light pointed to screen to see data turned on, if seen the CCFL is dead.(aka, background light tubes)
6/6/2022 12:42:55 PM •
Biostar...
Answered
on Jun 06, 2022
Audio Adapter ESS Technology ES1938/ES1941/ES1946 Solo-1(E) AudioDrive for windos 7
no PC told no OS told but it was for XPbiostar ended support. windows 7 is oct 2009 OSthe old XP driver is here.https://www.majorgeeks.com/files/details/ess_sound_card_es1938es1946_(es1969).html2006 sound cards. it is PCI not PCI-expressso is useless on all modern PC>but since you imply it fits to a PC the PC is a relic and not told the chip sets on the card are not supported by them maker of the chips so is double dead.(product line not maker)https://www.esstech.com/as you see no es1938 era support.if you google things that do not exist the prize is a nasty virus, here is a short test for w7 just for you.the waybackmachine.com shows https://www.esstech.com/going dead (for legace) 2007so dead 2 years before w7 was released.XP lasthttps://web.archive.org/web/20070202023729mp_/http://www.esstech.com/techsupp/drivers.shtmas you can see the FTP links to the drivers are dead.for ever and ever.now to w7 year, 2009 dec, 2 months from w7 releasetiming is everything , no?the endhttps://web.archive.org/web/20091213143106/https://www.esstech.com/they ended all legacy then./ that means so did biostar. with no base drivers it ends.RIP ESS legacy.
5/17/2022 7:12:49 PM •
Biostar...
Answered
on May 17, 2022
