20 Most Recent
AudioBahn A2200HCT Car Audio Amplifier Questions & Answers
I have 4 gauge wire to my audiobahn2200 htc and it
I would take an ohm meter and check the ohms on the subs sounds like you are dropping below 2 ohms.If the subs are new then that is normal its the coating on the voice coil getting hot but it will pass in time. I would recommend a 1-2 farrad cap for that set-up though.
10/24/2009 2:56:28 AM •
AudioBahn...
Answered
on Oct 24, 2009
Can it handle two subs bridged? cuz mine smells
What size are the power/ground wires? This is most likely the problem. If you are running that thing to the max, you will need a 2 or 4 gauge wire. Do it quickly, this starts a lot of fires when the wire melts.
10/24/2009 2:10:27 AM •
AudioBahn...
Answered
on Oct 24, 2009
HELP PLEASE
Your amp is die.... Go to the service center of your amp
7/18/2009 9:15:12 PM •
AudioBahn...
Answered
on Jul 18, 2009
Ground wire has burned plastic cover on my amp
what type of terminal is on the amp. screw or slip on type?
The plastic does not carry any type of ground. If your ground wire was melted, that means you have a 'hot' wire shorting across the ground somehow causing a short. This causes excessive heat like an 'arc' welder.
You might want to check your power wire to make sure its not making any contact to ground. Make sure any foreign debris is not causing a 'bridge' between the 2 posts.
If your terminals (or place where you hook up power and ground wires) are in good shape, re-wire and turn on the unit.
2/16/2009 5:59:31 PM •
AudioBahn...
Answered
on Feb 16, 2009
No noise A2200HCT
To determine what failed, you would have to open the amp while it's powered up and measure the voltage at several points. If you're not comfortable with doing this, you should pay to have it repaired. If you want to try to repair it yourself, read through the following page.
Basic Amplifier RepairYou'll need a digital multimeter.
Let me know if you want to try to repair it yourself.
11/30/2008 5:54:22 AM •
AudioBahn...
Answered
on Nov 30, 2008
Red Status Light
The most common cause for the protection LED to be lit is shorted output transistors. I'm not familiar with that amp but if you can send me some decent quality photos of the insides, I can tell you what to check.
You should only continue if you intend to replace the defective transistors yourself.
[email protected]
6/25/2008 6:11:31 AM •
AudioBahn...
Answered
on Jun 25, 2008
I need to hook up two audiobahn A1200Q subs to a
The amplifier is only stable to 2 ohms.
Assuming the cubs are dual 4 ohm voicecoils - a 2 ohm load with 2 subs is not possible.
You can only wire up 1 dual 4 ohm voicecoil sub (both positives to amp... and both negatives to amp) to get a 2 ohm mono load.
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Can the Audiobahn AEQ8 replace an Audiobahn AEQ6Q. Is it the same foot- print, size and rae connections similar..
Hello William Novelli, if it would be compatible, but you should control the order of the connections, they can vary
I send you the link to download the manuals of both models and compare the connections, if you find it complex, consult a specialized technical service
I hope you find it useful
Regards Franco Dosil
Hola William Novelli, si seria compatible, pero deberas controlar el orden de las conexiones, pueden variar
Te envio el link paravque descargues los manuales de ambos modelos y compares los conexionados, si te resulta complejo, consulta con un servicio tecnico especializado
Espero te resulte util
Saludos Franco Dosil
https://manualmachine.com/audiobahn/aeq7/18414-user-manual/
https://manualmachine.com/audiobahn/aeq8/18268-user-manual/
https://www.manualslib.com/manual/211695/Audiobahn-Aeq6q.html
I have a audiobahn aw1251t 12 inch sub and punch 1000-1db amp how would i wire it up
as your sub is only rated to 400w rms simply connect the sub to either a or b channel outputs you may wish to use an rca splitter before the amp to feed both left and right audio channels into a single channel on the amp. WARNING connecting both channels on the amp to the sub will overload the sub and possibly blow it up so i highly recommend not doing so.
Hi, I have 2 10 Audiobahn aw1000x,4ohm,
dual v.c,600watts each. ...but I can't find information on this model of subs ANYWHERE. I'D love to have a manual, or at least the specs... can anyone help?
i was not able to locate a manual but i did find some interesting information that hopefully may help,
The AudioBahn AW1000X Car Subwoofer Features: dual 4-ohm voice coils, non-pressed pulp cone, huge foam surround, frequency response 23-500 Hz, power range 50-600 watts RMS (300 watts per coil), peak power handling 1,200 watts, sensitivity 91.1 dB, top-mount depth 5-1/4" ,sealed box volume: 0.4-.95 cubic feet, ported box volume: 1.632 cubic feet.
