20 Most Recent
LG GWA-4164B DVD±RW Burner Questions & Answers
My LG GWA 4146b wont read any disk i put in, just
is it for a particular disk or all??
assuming for 'all' and with all data cables n jumpers r sitted correctly....
if u r a professional, open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
..contact ur System Admin/Vendor....
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
How to sync TCL ROKU TV to LG sound bar
You will need to connect a single HDMI cable from your sound bar to the HDMI ARC or the HDMI eARC port on the Roku T.Make sure that both of the devices are both turned on.When your TV detects the sound bar,it will then automatically initiate the setting up process. Lastly follow the easy on screen instructions to finish setting up the connection.
LG 55UM7300PUA not powering on
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
