20 Most Recent
LG GH22LS40 DVD-RW Burner Questions & Answers
I have HL-Dt-St DVDRAM GH22LS40
The issue is with your burner. Bet you a cup of coffee (milk and no sugar) that if you replace the unit all of your issues will be sayonara!
DVD Driver does not display on my desktop
While your computer is off, remove the DVD-RW Burner or just unplug the cables connecting it to your computer, then boot up your computer, then shut it down again and reconnect all of the cable connectors, then power on again a wait a couple of minutes. Windows 7 should find the drivers for your burner. If it continues to not load the drivers, then there may be something wrong with the burner itself.
The computer can not read the DVD rom, its not
try to run system restore. but if it doesnt work. check the functionality of the drive in safe mode (by pressing f8 when the computer turns on, dont wait for the windows logo to come up, you need to press f8 before the windows logo screen) try to explore whats on the disk and if it works. delete upper and lower filter by following the path. click start, click run, type regedit, hkey local machine/system/currentcontrolset/control/class/4d36e965-e325-11ce-bfc1-08002be10318
if you upper filter and lower filter, delete both. restart th computer and that should do it.
CD Burner will playback but will not record?
first reinstall the Burning software.. still if it doesnt work.. Update the Firmware of the Drive.. u can locate the drive firmwareon the LG site.. search for the firmware that matches the entire name of the drive.. if its not working after the update then replace the drive..
Lg super multi securdisc driver
Optical drives (at least all modern one's) do not require a driver when run in a Windows environment. The OS provides the support automatically. Is the drive shown/listed in My Computer?
Drivers needed
available here http://www.driverscape.com/download/hl-dt-st-dvdram-gh24ls50-ata-device
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
