20 Most Recent Samsung External Slim DVD-W USB Compatible with Mac and PC SE-S084C/RSBN Burner Questions & Answers
I can get it to dvd on leveno flex 10
Hi, have you changed into play mode from work mode? Do not forget this is a dual mode machine, work mode may not allow the playing/viewing of dvds
6/10/2015 1:54:31 PM • Samsung External... • Answered on Jun 10, 2015
I have the external slim dvd writer model SE-S084.
hi
you have problem with software
just goto nero burning software then try it will work for any DVD player and PC's
it come along wiht Desktop DVD driver
5/17/2015 7:47:17 PM • Samsung External... • Answered on May 17, 2015
How i can reset the bad ubdate of my optical external drive.I have nit a dvd.
I would start here. http://www.samsung.com/in/support/category/storage/opticaldiskdrive/ . You can get into live chat to find out your options to correct this. They will probably ask for your model & serial number. It's possible the FW update file was corrupted.
2/3/2015 2:34:19 PM • Samsung External... • Answered on Feb 03, 2015
Hi, I'm facing problem to burn cds using this appliance.
use a diffrent program to burn them with normally that helps have installed the drivers that came with device if not try that too and update windows that can sometimes help
4/27/2013 10:32:09 PM • Samsung External... • Answered on Apr 27, 2013
I have a Samsung SE-S084. Won't Write DVD's
Go here and click on Driver.
You should see what you need somewhere in that list.
Good Luck!
11/12/2012 8:50:34 PM • Samsung External... • Answered on Nov 12, 2012
Lost of code(39)
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question/exclamation mark ? ! or a red X right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver if your computer came with a motherboard disc the sound drivers could be on it you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate found new hardware wizard if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete After deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps
5/11/2012 4:54:24 AM • Samsung External... • Answered on May 11, 2012
How to attach to a mac mini
plug in the USB cord...it should be plug-and-play. This means you just give it a minute after plugging it in and it will install itself.
3/26/2012 9:16:03 PM • Samsung External... • Answered on Mar 26, 2012
0answers
SE-S084
Be the first to answer 12/12/2011 5:19:42 PM • Samsung External... • Posted on Dec 12, 2011Be the first to answer
I cannot get my pc to recognize my dvd burner. I
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps you
9/25/2011 12:54:06 AM • Samsung External... • Answered on Sep 25, 2011
The cd that comes with
Clearly the CD needs to be broken into more than two pieces. Or swapped out for an unsplit CD at the shop, where they can make a copy for you of course. Or or course you write the maker's local office. There's no need for the particular thing though; there's quite good free burning software around.
9/10/2011 8:53:58 AM • Samsung External... • Answered on Sep 10, 2011
As asoon as I connect
That's fine and all; I can imagine the DVD writer needs a powered hub to do any writing, though, so try that; but what exactly does the error message say, and what in the world can be saying that? USB is clearly a hotplug (any time) connection, though you could say what it's doing while 'sorting' if it does portend to do anything.
9/10/2011 8:48:27 AM • Samsung External... • Answered on Sep 10, 2011
When I try to play
Good day..!!Maybe your using cd disk that why ur external wont accept it.,or maybe there was a error on your cd.thanks
8/17/2011 10:28:54 AM • Samsung External... • Answered on Aug 17, 2011
The icon of samsung slim
Click on the finder button at the lower right of your computer then click the application folder then you will see there the icon for your external DVD
7/13/2011 6:15:04 AM • Samsung External... • Answered on Jul 13, 2011
CDs play, but unable to
ran into the same issue but with a mac book no "drivers" avail for the mac to let it communicate to burn. i did get around it by using a few free burning programs i just wish i could remember the name
5/14/2011 1:49:48 AM • Samsung External... • Answered on May 14, 2011
Hello I gota samsung dvd
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function!!!!
hope this helps
5/9/2011 1:42:22 PM • Samsung External... • Answered on May 09, 2011
2answers
Hey...i have an external dvd writer of samsung
make sure dvd drivers are reinstalled
2/28/2011 6:07:32 AM • Samsung External... • Answered on Feb 28, 2011
MY PC WONT RECOGNISE THE
Install to another pc or laptop.
It may be the operating system has not recognized all the ports, if you operating system is now ok, go to my computer>properties>hardware>device manager, and look to bottom of the list to USB Controller right click on them, and Uninstall all controllers and restart pc and see if all the ports are recognized and installed automatically.
If you need more information, reply me soon.
Thanks
2/25/2011 7:19:41 AM • Samsung External... • Answered on Feb 25, 2011
Won,t eject
I fixed mine by straightening out a paperclip and fiddling it around the small hole in the disc tray cover. Hope this helps
Thanks to ju.c for the solution
2/4/2011 12:15:24 PM • Samsung External... • Answered on Feb 04, 2011
Samsung External Slim DVD-W USB Compatible with Mac and PC SE-S084C/RSBN  Burner Logo
Popular Tags
68 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
reset bad ubdate optical external drive
  • Computers & Internet
