20 Most Recent LG GH22LP20 DVD±RW Burner Questions & Answers
The manual can be downloaded online by going to the below mentioned link:
http://www.manualowl.com/m/LG/GH22LP20/Manual/54774
Thanks,
E-ware
LG GH22LP20 ... | Answered on Jul 29, 2011
thats strange usually if it reads and burns dvd's it should be the same with cd's
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
LG GH22LP20 ... | Answered on Jul 13, 2011
your drivers may have been corrupted or you might have a virus run your antivrus program
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
LG GH22LP20 ... | Answered on Jan 26, 2011
make sure that the dvd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this dvd rw then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
LG GH22LP20 ... | Answered on Jan 06, 2011
Hi Terry, While I don't have a specific answer for you, I have links and information that should help you resolve the issue. Hope this helps you.
LG GH22LP20 ... | Answered on Dec 29, 2010
A_David_M
If you are having trouble burning with both programs this could be an issue with the drive its self.
How long have you had the drive for. I normally have to replace my burner about every 3 to 4 years.
Do you have access to another drive that you can try in your computer or another computer that you can try your drive in to see if you get the same problem.
Issken
http://www.fixya.com/users/issken
LG GH22LP20 ... | Answered on Aug 30, 2010
Did you install the software that came on the CD-ROM that came with the LG device?
What software are you using to view your DVD? PowerDVD? VLC? Other?
LG GH22LP20 ... | Answered on May 29, 2010
I had the exact same problem with my LG model GH22LP20 DVD drive. This is how I solved my problem:
I finally solved this problem. It was a Cyberlink software problem; specifically the software bundled with my DVD which was a Cyberlink Suite w/ PowerDVD2_bing.gif 7.0.
After going 3 - 4 rounds, via email, with Cyberlink tech support in India I finally got them to put down their "100,001 mindless ways to solve a software problem" manual and they emailed me a link to download a slightly newer version of the software; it was Cyberlink Hi-Def Suite, w/ PowerDVD 7.3.
I uninstalled my bundled software, and installed the newer software they gave me. After installing the newer software everything worked perfectly. If you're still having problems and have the same software version I started with, keep bugging Cyberlink tech support (be patient and diligent) until they acknowledge it's a software problem and send you a download link for a newer version. Good luck!
LG GH22LP20 ... | Answered on Mar 30, 2010
this vary with different made and models.check your manual to confirm the speed.Most of these are classified in terms of writing speed, reading speed etc.It is nothing to worry about,...
LG GH22LP20 ... | Answered on Mar 14, 2010
Try this site it is LG http://www.lge.com/products/category/list/computer%20products_optical%20storage_super%20multi%20dvd%20rewriter.jhtml
I would appreciate your positive rating
LG GH22LP20 ... | Answered on Mar 05, 2010
Do you have skipping on every DVD/CD you burn? If so, then you're probably experiencing what's called 'buffer underrun'. When that happens, the burner writes faster than the computer can send it information, resulting in skipping. In the program you use, look for the 'burn options' and change the speed from 'automatic' to a manual, slower setting. That should fix your problem.
LG GH22LP20 ... | Answered on Feb 24, 2010
maybe dvd codecs. serach it in google
LG GH22LP20 ... | Answered on Feb 05, 2010
Use Uniblue Driver 2009 cracked from loadevery.com
If it don't work then there must be the problem with DVD RW
Vote for better Attention
LG GH22LP20 ... | Answered on Oct 11, 2009
Ok some where on the DVD drive ther is a diagram of those 6 pins and the jumper. Or if you look on the bottom and the top of the drive you may see 3 abbreviations as follow MA, SL, CS. Place the jumper verticle on the pins that are directly above or below CS. That refers to those pins for the jumper to be on for the drive to be set to Cable Select mode. Cable Select means whatever part of the cable the drive is on it will automatically set the drive to Master or Slave.
LG GH22LP20 ... | Answered on Sep 13, 2009
the computer should recognize it as a dvd-device though, if not windows is giving u trouble,
so try using any other
freeware burn program like nero or burnatonce to burn,
u necessarily need the original software.
to get anew copy of software email the manufacturer, then post send the cd in exchange for a newer one or look on th homepage if they have something fittng your drive- model and operation system ready to download...
good luck
LG GH22LP20 ... | Answered on Sep 02, 2009
Optical drives (at least all modern one's) do not require a driver when run in a Windows environment. The OS provides the support automatically. Is the drive shown/listed in My Computer?
LG GH Computers... | Answered on Jul 04, 2014
available here http://www.driverscape.com/download/hl-dt-st-dvdram-gh24ls50-ata-device
LG GH Computers... | Answered on Dec 26, 2013
LG GH22LP20  DVD±RW Burner Logo
16 questions posted
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GH LG
  • GH LG
Most Popular Question
all sudden
  • Computers & Internet
