20 Most Recent LG GH22NP20 22x Internal DVDRW Retail Kit DVD±RW Dual Layer Burner Questions & Answers
3answers
Free download for lg dvd drivers gh22np20
I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing LG drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues.Best regards!
4/17/2014 7:50:08 PM • LG GH22NP20 22x... • Answered on Apr 17, 2014
0answers
Driver
Be the first to answer 5/7/2013 3:16:10 AM • LG GH22NP20 22x... • Posted on May 07, 2013Be the first to answer
Dvd unreadable
I believe you are having issue with the DVD drive reading DVD's is that correct?
You did not mention the Windows Version you have.
But then again regardless what Windows you may have you can follow these steps to see if the DVD issues can be corrected.
Click on START, then Click Run, on the Run window type regedit the press enter or click on OK
the registry editor should show up on the screen.
Once you have the Registry Editor follow these HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
click on each category then on the last fer class will be the DVD drive itself, on the right pane windows you will see CD/DVD-ROM drives, look for Upper and Lower filters delete both by right clicking on each, after deleting restart windows.
For a Vista or Win7 OS it will basically almost be the same, but instead of looking for Run in the begining just click Start then on the start search portion where you can type just type in CMD then it will show on the list left pane windows that is where you can right click on it then select run as administrator then you can do the same steps above to get to the DVD drive upper and lower filters.
I hope that this will help.
Have a nice day.
8/9/2011 1:27:59 PM • LG GH22NP20 22x... • Answered on Aug 09, 2011
How many years warranty on lg dvd writer
System comes with 1 year standard return to base parts and labour warranty.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button and leave ashort comment to let other people know how I help you. Have a good one!
7/27/2011 9:08:57 AM • LG GH22NP20 22x... • Answered on Jul 27, 2011
0answers
Light flashes but won't play disc
Just change your data cable.
Regards
2/26/2011 5:54:10 PM • LG GH22NP20 22x... • Answered on Feb 26, 2011
How to connect camcoder for recording ?
You need a pc, connection wires that connect the recorder to the pc (usb port or video card). windows live or other video software.
2/13/2011 7:57:45 PM • LG GH22NP20 22x... • Answered on Feb 13, 2011
I have three lg dvd
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall hope this helps
1/26/2011 4:45:39 PM • LG GH22NP20 22x... • Answered on Jan 26, 2011
Drive not working.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
1/25/2011 3:16:42 PM • LG GH22NP20 22x... • Answered on Jan 25, 2011
Drive started burning 16x at
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall you might uninstall your burning software restart your computer then reinstall the burning software or scroll to the bottom taskbar/toolbar right click select taskmanager applications ,processes you can see what
1/22/2011 9:58:11 PM • LG GH22NP20 22x... • Answered on Jan 22, 2011
FOR THE GH22NP20 hafe im
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall hope this helps
1/17/2011 8:21:29 PM • LG GH22NP20 22x... • Answered on Jan 17, 2011
It can read and detect discs, but cannot burn
Hi Jaun,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not burn a DVD, chances are your DVD burner componet needs to be replaced. Good Luck.
  • If this helps resolve your issue, would you please rate the solution
12/30/2010 9:22:19 AM • LG GH22NP20 22x... • Answered on Dec 30, 2010
Can't detect disc
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is noharm in trying If you take a little riskcan solve . follow the instruction: Don'tpanic its very simply.
  1. When running your pc , open the drawer.>
  2. switch off the ac power
  3. remove power cable & sata or pata cable
  4. remove all the screw from the back side
  5. press clip to open the font panel
  6. reverse the cd/dvd rw
  7. just remove the cover
  8. clean the optical lance
  9. http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
  10. use a little ( not much )oil place on two steel shaft
  11. cover all the equipment
  12. now you can fit to your pc
Ifit does the same problem please change the cd/dvd rw because the lance has defected.
Hopeit will help you. Don'tforgate to vote me.
12/25/2010 6:42:16 AM • LG GH22NP20 22x... • Answered on Dec 25, 2010
Reading problem
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
12/16/2010 9:37:27 PM • LG GH22NP20 22x... • Answered on Dec 16, 2010
My lg dvd drive read film dvd as a blank dvd
Clean the DVD with water and shampoo if it is scratched.
If the problem happens with most DVDs, then you have to try get a replacement if it is under warranty.
8/13/2010 12:34:50 PM • LG GH22NP20 22x... • Answered on Aug 13, 2010
Hi am new in FixYa
try getting a DRY cotton bud and gently wipe the laser lens (while off) and try a disk.
let me know how it goes.
8/6/2010 12:10:41 PM • LG GH22NP20 22x... • Answered on Aug 06, 2010
Ive lost my cd driver for LG cd writer
I have lost my cd driver for LG DVD rewriter
7/14/2010 1:55:17 AM • LG GH22NP20 22x... • Answered on Jul 14, 2010
LG GH22NP20 22x Internal DVDRW Retail Kit DVD±RW Dual Layer Burner Logo
34 questions posted
Top LG Computers & Internet Experts
Marvin
Marvin
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GH LG
  • GH LG
Most Popular Question
free download lg dvd drivers gh22np20
  • Computers & Internet
