20 Most Recent HP dvd1170e DVD-RAM Burner Questions & Answers
Hi Have a HP DVD1170E drive
well how can it be new? (new old stock you meant) or new to you? its at least 10 years old.. an old Desk top drive. this is all there is now, they are deleting this section now. Questions of the day.? why run a 3year old dead,OS XP? its dead, that means when you need drivers its going to be hard to impossible to find or will by found but will be full of VIRUS. upgrade to w7. (buy a retail license for it and use it) (ask how) no system stated, just a DVD # cant help much with that. To make DVD and USB work right on XP it needs SP3. service pack 3, but finding it can be hard. no stores sell it (brick) no disks marked XP with SP3 now. plug it in to a new machine, say w10 laptop or desktop if it plugs and plays that means windows still supports it. and if true may work with W7 too. then try it on w7? learn where it can work and where not. and save all this grief. https://support.hp.com/us-en/product/hp-dvd1100-dvd-writer-series/3980001/model/3980006/more-options
4/7/2017 4:58:45 PM • HP dvd1170e... • Answered on Apr 07, 2017
0answers
Mixed up my power supply for my dvd1170e external drive what is the correct input andoutput for this device?
You need one with the following attributes:Output Voltage: 12 Volts DCAmperage: 1.8~2 AmpsYou can buy a replacement at http://www.lcdpayless.com/productpage.php?productId=8562
11/25/2012 2:24:10 AM • HP dvd1170e... • Answered on Nov 25, 2012
Why does my HP dvd1170e burner always state
HelloHave you tried another USB port on the computer ,also try uninstalling and reinstalling Nero apart from that it could be a fault with the laser lense on the drive itself and will have to be repaired or in this case time to buy another one.
3/1/2012 4:40:17 PM • HP dvd1170e... • Answered on Mar 01, 2012
Cannt burn dvds or play dvds
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area If this does not fix the problem you might try you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or if this does not fix the problem it might be a registry problem Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps you
11/7/2011 6:39:15 AM • HP dvd1170e... • Answered on Nov 07, 2011
System does not recognize the
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps you
8/24/2011 4:41:21 AM • HP dvd1170e... • Answered on Aug 24, 2011
How do u use use lightscribe
Use the CD/DVD label maker program your burner should come with (or some other one). Create the CD/DVD label however you want, just don't be too extravagant... it may not come out very nice. Put your lightscribe CD/DVD media label-side down (upside down) into the tray and print away. Then you wait, wait, wait, and wait some more. Afterwards, you'll probably want to actually put some data on that disc.
7/27/2011 9:47:42 PM • HP dvd1170e... • Answered on Jul 27, 2011
Error 43 drive not recognized
make sure that the cd/dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd rw then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete After deleting the keys, close the registry editor Reboot your computer Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
4/17/2011 11:57:47 PM • HP dvd1170e... • Answered on Apr 17, 2011
Not recognizede in windows 7
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
3/27/2011 10:35:34 PM • HP dvd1170e... • Answered on Mar 27, 2011
I have been using my
You probably have a "pcoffin.sys and/or "pcoffin.dll" system file on the PC. It is a driver used by a number different DVD programs. I would not delete them at this point.
This is a link to some freeware software. You can try to see if you can burn a CD/DVD using this instead of the software giving you the driver error. There are tutorials on the site.
http://infrarecorder.org/?page_id=5
2/25/2011 3:40:53 PM • HP dvd1170e... • Answered on Feb 25, 2011
Dvd stuck in player
u will notice a small hole in the front of ur dvd/cd. (usually on right side) us a needle or paperclick, insert it into the hole, push slightly and ur unit will open cheers...PK
1/14/2011 10:05:04 PM • HP dvd1170e... • Answered on Jan 14, 2011
The burner will work with no problems on a slow
first up
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
1/9/2011 10:42:13 PM • HP dvd1170e... • Answered on Jan 09, 2011
HP dvd1170e DVD Writer It now
scroll to the bottom toolbar (bottom of screen) right click you will see task manager application you will see whats running on your computer at the time you are burning also if you are connected to the net when you are burning this might be slowing the burn process
hope this helps
1/5/2011 10:00:58 PM • HP dvd1170e... • Answered on Jan 05, 2011
How do I open the case to remove something without
If the carriage is blocked , there is a smole hole on the front pannel . Open a paper clip and push it trough the hole . The carriage will open .
1/3/2011 5:57:29 PM • HP dvd1170e... • Answered on Jan 03, 2011
0answers
HP dvd1170e DVD-RAM Burner Logo
35 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
system not recognize
  • Computers & Internet
