20 Most Recent
AudioBahn A4601T Car Audio Amplifier Questions & Answers
Amp Problem
my first thought would be the rca's. make sure the rca's are in good condition and also make sure that their in the right spot from the head unit. (some head units have multiple rca outputs or inputs) and be sure that your gains and levels are all set right
I need to hook up two audiobahn A1200Q subs to a
The amplifier is only stable to 2 ohms.
Assuming the cubs are dual 4 ohm voicecoils - a 2 ohm load with 2 subs is not possible.
You can only wire up 1 dual 4 ohm voicecoil sub (both positives to amp... and both negatives to amp) to get a 2 ohm mono load.
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Can the Audiobahn AEQ8 replace an Audiobahn AEQ6Q. Is it the same foot- print, size and rae connections similar..
Hello William Novelli, if it would be compatible, but you should control the order of the connections, they can vary
I send you the link to download the manuals of both models and compare the connections, if you find it complex, consult a specialized technical service
I hope you find it useful
Regards Franco Dosil
Hola William Novelli, si seria compatible, pero deberas controlar el orden de las conexiones, pueden variar
Te envio el link paravque descargues los manuales de ambos modelos y compares los conexionados, si te resulta complejo, consulta con un servicio tecnico especializado
Espero te resulte util
Saludos Franco Dosil
https://manualmachine.com/audiobahn/aeq7/18414-user-manual/
https://manualmachine.com/audiobahn/aeq8/18268-user-manual/
https://www.manualslib.com/manual/211695/Audiobahn-Aeq6q.html
I have a audiobahn aw1251t 12 inch sub and punch 1000-1db amp how would i wire it up
as your sub is only rated to 400w rms simply connect the sub to either a or b channel outputs you may wish to use an rca splitter before the amp to feed both left and right audio channels into a single channel on the amp. WARNING connecting both channels on the amp to the sub will overload the sub and possibly blow it up so i highly recommend not doing so.
Hi, I have 2 10 Audiobahn aw1000x,4ohm,
dual v.c,600watts each. ...but I can't find information on this model of subs ANYWHERE. I'D love to have a manual, or at least the specs... can anyone help?
i was not able to locate a manual but i did find some interesting information that hopefully may help,
The AudioBahn AW1000X Car Subwoofer Features: dual 4-ohm voice coils, non-pressed pulp cone, huge foam surround, frequency response 23-500 Hz, power range 50-600 watts RMS (300 watts per coil), peak power handling 1,200 watts, sensitivity 91.1 dB, top-mount depth 5-1/4" ,sealed box volume: 0.4-.95 cubic feet, ported box volume: 1.632 cubic feet.
Brand new Audiobahn amp burning smell
i'd need more info but from what you've stated, sorry to break it to you but it sounds likely you've incorrectly wired you speakers and blown your amp. this will prove no doubt an expensive mistake and learning exercise.
I have a 2 ohm
Generally there are 2 parts to this problem
part 1
input signal as these woofers are just subs remember to give them a low line in signal before the amp (see diagram) i like to use rca low pass crossover filters from harrison labs (see link)
part 2
is the wiring configuration of the 2 woofers by wiring them in parallel as shown in the diagram you reduce them to a 2 ohm load for your 2 ohm amp meaning you'll get max loudness and efficiency
Harrison Labs FMOD Inline Crossover Pair 100 Hz Low Pass RCA Shipping is...
