20 Most Recent Waring WPM25 Popcorn Maker Questions & Answers
use a non contact voltage detector pen and follow the wires from bottom up to bowl heater , somewhere along the way the power will stop , thats the device that needs some looking at
Waring WPM25... | Answered on Jan 20, 2015
using a non contact voltage detector pen veryify that Kettle is recieveing power , if not ck two things 1st the switch for heat function ,use same pen as ist step , both sides of switch , In and out wire , second ,overtemp switch this is down by heater coils and maybe a little tricky to acess with power applied ,be carefull !! use same pen to follow power all the way to heater coils , if it gets there and still no heat then the coils are burned out , this happens if unit was heated up without any oil or corn inside
Waring WPM25... | Answered on Jan 17, 2015
Check the wires to the heating element inthe kettle.
Waring WPM25... | Answered on Jul 05, 2010
You need to dry it as much as you can by hand, then take a hair dryer and see if you can dry it the rest of the way. You may need to open things up to expose the cirucitry and check for water.
Waring WPM25... | Answered on May 17, 2010
Waring would be a possible source.
Waring Kitchen... | Answered on Dec 24, 2019
If it is a removable cord, you will get one in a good electrical shop, or online by describing the connector.
If hard wired, you can buy a plug with wire attached at home depot and fix it yourself by removing the place where the wire goes in.
https://www.google.com/search?q=new+cord+for+my+old+Waring+Steam+Chef+CS510
This shows the model. It has a special bespoke connector
https://www.worthpoint.com/worthopedia/waring-steam-chef-cs510-model-11cs12-253544648
You can get a new, used on one for 20 bucks.
https://www.ebay.com/c/1301639892
Waring Kitchen... | Answered on Jul 09, 2019
The reset can trip if there is a short circuit or the unit is over-heating. Either condition is dangerous. Unless you can locate the problem, for safety reasons suggest replace the entire unit with a new one.
Waring Kitchen... | Answered on Apr 23, 2019
Linkco perhaps. That may be a general supplier.
Waring Kitchen... | Answered on Jan 19, 2019
Kudos to the person(s) that identified the safety switch on the housing. Mine would not turn on because the switch would not depress, perhaps the plastic insertion piece on the frame was a little off. I tried wedging aluminum foil and plastic etc, but if you don't depress the black button in the middle of that white shroud on the switch exactly right, it won't work.
My solution was to permanently attach a 1/2 inch deck screw thru the housing so that the screw tip keeps the switch depressed always.
Turn the unit on its left side, use a very small bit to make a pilot for your screw. Very carefully and slowly screw down until the tip activates the switch. I don't believe there is a circuit board or anything in the vicinity, and I left mine plugged in so I would know when I hit paydirt. Caveat emptor and good luck!
Waring Kitchen... | Answered on Dec 22, 2018
go to fastenal hardware or any store that sells hardware to match one up
Waring Kitchen... | Answered on Dec 19, 2018
continue beeping there is a sensor or switch not normally operate. How to Fix by open you waffle maker assembly.
wwm450pc_(costco)_ww_1-qooiw4fc5lrzbika4rggwo4o-1-9.gif Trace the switch that causes beeping
Waring Kitchen... | Answered on May 03, 2018
Try Googling (waring)(w0508)(manual) without parens.
Waring Kitchen... | Answered on Dec 26, 2017
Try Googling (waring)(PS101)(manual) without parens.
Waring Kitchen... | Answered on Dec 12, 2017
Waring WPM25 Popcorn Maker Logo
Popular Tags
4 questions posted
Top Waring Kitchen Appliances - Others Experts
Jim
Bruce Eichhorst
Ps Daengr
Ps Daengr
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Waring Kitchen Appliances - Others
Most Popular Question
waring pro popcorn maker not heating
  • Kitchen Appliances - Others
