20 Most Recent Frigidaire ATF6700FS Front Load Washer Questions & Answers
Please go to this link. There you will have your manual. https://www.manualowl.com/m/Frigidaire/ATF6700FS/Manual/287375?page=1
Frigidaire... | Answered on Nov 03, 2015
Good Afternoon Friend,
I understand you want to know where the filter is located on your Frigidaire washer, model# ATF6700FS2. The filter is located in the front right hand side of your appliance. It is located between the tub and the drain pump. If you are trying to get to the filter, this is typically not a do it yourself job, as there are no step by step instruction manuals. I would suggest contacting your local authorized technician if you need assistance. They have been trained on your appliance and will be able to best assist. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 10, 2014
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Frigidaire... | Answered on Jun 25, 2014
Hi Curt, this is AP
I understand you are having trouble with an error code on your Frigidaire front load washer. On your particular model, ATF6700FS, the error code "DR" indicates that the door is open or there is a problem with the door. If you know the door is not open you should check the door switch and wiring. If you need assistance with replacing the door switch I would recommend contacting an authorized technician in your area. I hope this information proves helpful to you, thank you for the post.
Thanks,
Frigidaire... | Answered on Apr 01, 2014
there is a trap in the large hose between the tub and the pump it needs to be cleaned out, make sure you re-install it properly or you will have worse problems. If you need further instructs I will help you
Frigidaire... | Answered on Mar 30, 2014
Check the water valves to be sure they are on. Then if they are, you may have a controller issue because one of the water valves should work, either hot or cold. If they both stop working it is usually not the valve.
Frigidaire... | Answered on Mar 29, 2014
I have checked with local supplier and found out that the part number for Affinity atf6700fs1control board is 137006030, since I can not return it, could anyone confirm it for me? Thanks!
Frigidaire... | Answered on Dec 12, 2013
Door lock probably needs repalcing. Try unplugging unit to reset control board first.
Frigidaire... | Answered on Aug 14, 2013
Door lock probably needs replacing.
Draining problems usually are a result of a blocked or failed pump. From what I can tell, your model of machine does not have easy access to the pump. However, if you were confident, you could UNPLUG the machine, remove the cover, and inspect the pump yourself, or get someone who is qualified to do so.
Frigidaire... | Answered on Feb 02, 2013
Look at this video. The filter is in the black boot the runs from the tub to the pump.
Frigidaire... | Answered on Dec 05, 2012
Frigidaire ATF6700FS Front Load Washer Logo
57 questions posted
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
frigidaire affinity washer manual
  • Washing Machines
