20 Most Recent Mach Speed Trio V430 MP3 Player Questions & Answers
Try ` www.lazysoft.com
Col. Dana Gillespie
Mach Speed Trio... | Answered on Oct 03, 2014
is blue window
Mach Speed Trio... | Answered on Jan 05, 2014
Check the specification of your MP3 player to determine the type of video file format it uses. Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses. After video conversion then copy the video files to your MP3 player using the USB cable from your computer. Click on this link for instructions on converting video files for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
Mach Speed Trio... | Answered on Mar 29, 2013
Check the specification of your MP3 player to determine thetype of video file format it uses.Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX.If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. After video conversion then copy the videofiles to your MP3 player using the USB cable from your computer.Click on this link for instructions on converting videofiles for MP3 players :-http://www.fixya.com/support/r5874192-play_videos_mp3_player
Mach Speed Trio... | Answered on Jun 30, 2012
i think in 3 possible solutions: 1- try to charge it with another charger 2- connect your mp4 to a computer and run a virus scan, after this try it. if don't, format your mp4 and try to charge it again. 3- the charge system of your mp4 is damaged, so take it to the technical support for to repair it.
Mach Speed Trio... | Answered on Aug 06, 2011
When you buy it, it comes with a USB cable and a charger, you juste have to plug it in and it will recharge.
Mach Speed Trio... | Answered on Jul 19, 2011
I am very sorry you are experiencing this problem. I will be more than happy to help. Try reloading the software. This seems like a software incompatability issue.
Thanks,
FixYa Expert
****Please Rate Thumbs Up if you like my Solution****
Mach Speed Trio... | Answered on Jul 18, 2011
Welcome to Fixya. It seems that the problem is caused by the battery of your device. It wont take any charge.
You can check the warranty of your device nad if still have warranty you can send it for RMA
You may be able to get it repaired at no charge if it is under warranty and the malfunction is covered. Mach Speed's warranty information can be found here
Thanks for using Fixya.
Mach Speed Trio... | Answered on Apr 14, 2011
In this case I'd suggest that you format your player. Contents may be removed by using this function. So make sure to back up your contents. You can sync your player with Windows media payer version 10 or above.
Here is how to format it:
1. Connect the MP3 player to a working USB port. Locate the drive created by the unit, generally just called Removable Disk, with a letter in Parenthesis. Drive letters vary depending on your system configuration.
2. Right click on the removable drive icon which is your player's icon and select format from the drop down menu.
Your MP3 player will now start formating. Follow onscreen instructions and disconnect when format is completed.
Hope this helps.
Mach Speed Trio... | Answered on Mar 18, 2011
You may be able to get it repaired at no charge if it is under warranty and the malfunction is covered. Mach Speed's warranty information can be found here.
You may reach their Technical Support department by phone at 580.272.0035 or by filling out a contact form here.
Mach Speed Trio... | Answered on Mar 01, 2011
has a broken screen how can i replace
Mach Speed Trio... | Answered on Feb 20, 2011
MP3 players have a reset somewhere on the chassis, you should see a small pin hole, use a safety pin and hold it down for 60 seconds to clear the processor so it can reset.
Mach Speed Trio... | Answered on Feb 11, 2011
Go to the explore mode and you will see your card there.
im sorry with a computer stuff that you delete is stored untill more stuff is deleted to write over the top but with stuff like this it is not and if it was deleted from the pc even it will not store them as the files are not native im sorry to give you bad news buy i have answered your question and even though i knew the answer i checked for a long time to see if any programs could restore stuff but *** i thought they cant as there is no were to store the files that have been deleted please make your payment as soon as possible as we have been having trouble with people not paying recently thanks
Mach Speed Trio... | Answered on Jan 19, 2011
The MP3 player uses a USB cable to download music files from the computer. Windows 98 does not support USB port even if the computer has a USB port. If the computer has a USB port then you need to install a Windows 98 USB driver so it can connect with the MP3 player to download mp3 music files.
Mach Speed Trio... | Answered on Jan 14, 2011
Mach Speed Trio V430  MP3 Player Logo
Popular Tags
62 questions posted
Top Mach Speed Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Trio Mach Speed
  • Trio Mach Speed
Most Popular Question
put lyrics
  • Audio Players & Recorders
