20 Most Recent Pentax Optio W80 Digital Camera Questions & Answers
no you cannot edit the date imprint within the camera once its been clicked. you can just turn that setting off so that the date dosnt show up on the picture or change the date in your camera & click pictures again to your desired date
Pentax Optio W80... • Answered on Dec 08, 2014
The dpi is not really a camera setting. The camera should usually be set to the highest resolution possible (4000x3000). This capture size would give a print size of approx 13"x10" at 300dpi. That would be considered a high resolution print. If you were printing at "normal" print resolution you could double that print size.
Pentax Optio W80... • Answered on Jun 01, 2014
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Pentax Optio W80... • Answered on Nov 02, 2013
The feature is there as seen here and available in "Play back" mode.
set picture here
Pentax Optio W80... • Answered on Dec 28, 2010
Could you have accidentally placed the camera in macro mode?
Pentax Optio W80... • Answered on Oct 23, 2010
Never remove or insert a memory card while the camera is turned on. Try removing the battery, waiting about 30 minutes, and then putting in a freshly charged battery. Never remove or insert a memory card while the camera is turned on!!!!!!
Pentax Optio... • Answered on Apr 13, 2018
Put it in the airing cupboard to dry out for 48 hours
Pentax Optio... • Answered on May 11, 2016
Hi. Your camera is too old to accept that big a card. The camera will let you know what size it will accept. Just keep putting larger sizes until it stops. Hope that helps.
Pentax Optio... • Answered on May 29, 2015
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
Pentax Optio... • Answered on Feb 06, 2015
The Pentax Optio WG-2 takes an OEM manufactured battery or one designed for it. Google "Pentax Optio WG-2 replacement battery" or do a Amazon.com search for the same and you'll get thousands of options where to buy.
Pentax Optio... • Answered on Nov 07, 2014
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Pentax Optio... • Answered on Sep 15, 2014
Most of the time the charge light will change from red to green when the battery is full.
Pentax Optio... • Answered on Aug 28, 2014
Pentax Optio W80 Digital Camera Logo
6 questions posted
Top Pentax Cameras Experts
halotheracer
halotheracer
Steven Wander
Steven Wander
Mat Kramer
Mat Kramer
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
set 300 dpi
  • Cameras
