20 Most Recent Olympus E-510 Digital Camera Questions & Answers
How can I disable the multi flash on the Olympus
I'm not certain what you mean by "multi flash". I'll give you two answers. 1.) If you are attempting to take a picture under low light levels, the rapid flashing is the camera adding light to the scene for the autofocus to work. You may have to manually focus in these situations if you don't want the rapid flashing. 2.) The autoflash can be disabled with the flash button on top of the camera. Pressing it once will open the pop up flash. Pressing it a second time will bring up a menu on the screen. Highlight the lightening bolt with the line through it and press 'OK". Auto flash can also be disabled by using one of the scene modes such as low light, candlelight, night scene or fireworks.
9/2/2010 6:52:41 PM • Olympus E-510... • Answered on Sep 02, 2010
Why is my compact flash write protected?
The write protection is usually enabled by flipping an extremely tiny switch on either the side of the card or the adapter you may be using. Write protection keeps your data safe from being over-written.
5/14/2014 5:43:08 PM • Olympus E... • Answered on May 14, 2014
What does the card error mean
Can be lots of things. Would have been handy, if you had told what card you are using. Your camera can work with CompactFlash, Microdrive and xD-Picture cards. If you did not insert the card(s) you are using, correct, or you removed the card in a wrong way, you could have damaged the cardholder, causing an error you probably can't repair yourself. The CF and Microdrive you can remove by pressing the eject button. The xD-Picture card you can remove by pressing in the card, and release it. The card comes out. Then you could have damaged the file system, by opening the card cover, while the card access lamp was blinking. What ever card was in, the filesystem can be damaged. Then you can have two cards in, Both, o CF of Microdrive and a xD picture card. Some settings are required for the camera, to know hat card it should use. If you have an Microdrive, the drive can be damaged, by a magnetic file, or the drive just stopped rotating. A micro drive is actual a miniature spinning hard drive. First check if the memory card is inserted correct. Eventually, remove it and check all contacts, on the card and in the camera. Then try formatting the card. If you think there could be important pictures on the card, put it in a external card reader and use a recovery program, to see you can recover the pictures on your computer. Programs can be found on the net. If you can't format the card, check if you have a Microdrive. If so, try to replace that with a CF or xD card. I hope something is to any use for you. Next time, please give us some more details. I know you exactly see and know what is not working, but we only can use your description. And only what you give us.
2/16/2014 11:53:00 AM • Olympus E... • Answered on Feb 16, 2014
0answers
How to clear an sd card
The best way to clear your card is to format it. There should be a "Format" command somewhere in the menu system, probably under "Setup." Since you neglected to specify the model of your camera I'm afraid I can't point you to the exact location.
6/26/2012 5:00:24 PM • Olympus E... • Answered on Jun 26, 2012
2answers
Hi! can i use xD 2GB TYPE M+ CARD WITH OLYMPUS STYLUS 300 DIGITAL?
  • The Olympus Stylus 300 camera works with xD-Picture cards, including the 2GB Type M+ card. But it's important to make sure the camera can use that particular type and size of xD card by checking the camera's specifications and list of compatible devices.
4/3/2024 5:36:15 AM • Olympus Cameras • Answered on Apr 03, 2024
My Olympus fe320 has a blurry screen & takes blurry pics. Is there a fix / solution to this?
Could be a steamed up lense or just dirt from storage. It is over 10 years old so possibly past its best by date but take it to a photographic shop and ask them for an estimate.
9/20/2023 4:02:06 PM • Olympus Cameras • Answered on Sep 20, 2023
Olympus Tough T-100 12.0MP Digital Camera. How can I fix it? It is still not working.
Question edited for clarity. It sounds like your battery has failed or have you tried two of them? Is there a date on the battery? They don't last forever. Check the charger for output using a digital multimeter. Also try cleaning the battery contacts on the battery and in the camera. https://www.google.com/search?q=olympus+t100+battery Powered with a LI-80B Lithium-ion battery (recharged via the included AC adapter) you can enjoy shooting the T-100 for about 190 photos per full battery charge. ..
9/9/2023 7:40:29 PM • Olympus Cameras • Answered on Sep 09, 2023
Do you think I need a new battery?
test battery if failed replace
9/6/2023 8:49:48 PM • Olympus Cameras • Answered on Sep 06, 2023
2answers
My Olympus VR-340 is not working.
Locate the reset button on your camera, usually found in the battery compartment. Press and hold the reset button for a few seconds, then release it. This action may help resolve any software glitches causing the issue. myreminiapk.com
7/31/2023 9:48:19 AM • Olympus Cameras • Answered on Jul 31, 2023
Hi, My Using Olympus FL-36 flash won't allow me to access TTL? Was working fine. Replaced the batteries, unable to access TTL.
Make sure the camera hot shoe is clean and also the spring assisted contacts on the flash as in for order. https://www.google.com/search?q=Olympus+Fl+36+flash+won%27t+access+TTL ..
4/27/2023 4:58:49 AM • Olympus Cameras • Answered on Apr 27, 2023
2answers
Where can I locate firmware upgrades for the olympus ws-331m. The Olympus site no longer has them
You have answered your own question. Other software suppliers may contain false data; don't use them.
3/20/2023 10:13:23 PM • Olympus Cameras • Answered on Mar 20, 2023
Olympus WS-331M not holding time
There is likely to be a motherboard battery to hold memory, but it isn't documented. https://www.google.com/search?q=Olympus+WS-331M+motherboard+battery ..
3/17/2023 4:18:09 AM • Olympus Cameras • Answered on Mar 17, 2023
Olympus camedia c-370 showing lights but not opening
Hi, if you are searching for best gaming website, Aonbola77.net is best option for you.
3/11/2023 11:26:34 AM • Olympus Cameras • Answered on Mar 11, 2023
WHEN I TURN MY OLYMPUS ON IT GOES RIGHT TO "ZOOM ERROR" THEN SHUT OFF. ANY SUGGESTIONS?
When your Olympus camera goes straight to "Zoom Error" and then turns off, it is likely that there is an issue with the camera's lens mechanism. Here are a few things you can try to troubleshoot the problem:
  1. Turn off the camera and remove the battery and memory card. Then, wait for a few minutes before re-inserting them and turning the camera back on.
  2. Gently move the lens back and forth with your fingers to see if it can be moved and if it is stuck.
  3. Use a can of compressed air to blow dust and debris out of the lens mechanism.
  4. Check the lens for any physical damage such as cracks or dents.
  5. Try using the camera without the zoom function to see if it still turns off.
  6. If none of the above steps resolve the issue, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus camera is an older model camera, which makes it harder to find replacement parts and professional repair services. If the camera is still under warranty, you may be able to get it repaired or replaced by the manufacturer.
1/23/2023 6:41:12 PM • Olympus Cameras • Answered on Jan 23, 2023
My olympus sz 14 camera shows Zoom error on the screen when I turn it on and then turns off immediately. I bought a new battery a d charged the camera but it continues to shut off.
The "Zoom Error" message that appears on your Olympus SZ-14 camera's screen when you turn it on, followed by the camera turning off immediately, could be caused by a problem with the camera's lens. Here are a few things you can try to troubleshoot the problem:
  2. Try gently tapping the camera on a flat surface to try and realign the lens.
  3. Check the lens for any dirt or debris that may be blocking the movement of the lens. Clean the lens with a soft, dry cloth.
  4. Check the lens for any physical damage like dents or cracks.
  6. Contact Olympus customer support: If you have tried all the above steps and the camera is still not working, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus SZ-14 is an older model camera, which makes it harder to find replacement parts and professional repair services. If the camera is still under warranty, you may be able to get it repaired or replaced by the manufacturer.
1/23/2023 6:39:30 PM • Olympus Cameras • Answered on Jan 23, 2023
How to transfer photos taken by an Olympus Camedia C-1000 L to a computer?
To transfer photos taken by an Olympus Camedia C-1000L camera to a computer, you can use the following method:
  1. Connect the camera to the computer using a USB cable.
  2. Turn on the camera and set it to the "PC" or "Computer" mode.
  3. On your computer, a new drive or a pop-up window should appear, indicating that the camera has been recognized.
  4. Open the drive or window and navigate to the folder where your photos are stored.
  5. Select the photos you want to transfer and copy them to your computer by using drag and drop or "Copy" and "Paste" functions.
Alternatively, you can use the Olympus Camedia Master software that came with the camera to transfer photos. Once connected and the software is open, you will be able to see the camera's content, then you can select and transfer the photos to your computer. It's important to keep in mind that the Olympus Camedia C-1000L is an older model camera, which may not be compatible with the latest version of computer operating systems, so it's recommended to check the software and the operating system compatibility before transferring the photos.
1/23/2023 6:38:01 PM • Olympus Cameras • Answered on Jan 23, 2023
Olympus vn6200pc won't power on. I can plug into pc and play files and screen comes on but if not plugged into computer it wont come on. Tried disassembling but no obvious cause seen...
If your Olympus VN-6200PC digital voice recorder is not turning on, even when it's not plugged into a computer, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
  1. Check the batteries: Make sure that the batteries are inserted correctly and that they have enough power. If the batteries are low or dead, the device may not function properly. Try replacing the batteries with fresh ones.
  2. Check the power switch: Make sure that the power switch is in the correct position and that it's not stuck.
  3. Check the firmware: Make sure that the device's firmware is up to date.
  4. Try a factory reset: Some devices have a factory reset option that can be accessed through the menu or by holding down certain buttons. This will erase all data on the device, but it may fix some software issues.
  5. Check the charging port: Make sure that the charging port on the device is clean and free of debris.
  6. Contact Olympus customer support: If you have tried all the above steps and the device is still not turning on, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus VN-6200PC is an older model device, which makes it harder to find replacement parts and professional repair services.
1/23/2023 6:36:03 PM • Olympus Cameras • Answered on Jan 23, 2023
Olympus E-510 Digital Camera Logo
2 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
E Olympus
  • E Olympus
Most Popular Question
disable multi flash olympus
  • Cameras
