20 Most Recent Sony Alpha DSLR-A230 Digital Camera Questions & Answers
Not all cameras charge from the USB cord. Also there are some USB cords for data, some for charging.
Sony Alpha... | Answered on Nov 05, 2017
Check that the camera or lens AF/MF switch hasn't moved to MF.
This will turn off the auto focus on the camera.
You can see them both in this photo.
Sony Alpha... | Answered on Jan 16, 2015
I had the same issue. I believe that our cat knocked the camera off of our coffee table, a distance of only 16 inches or so. I searched the Internet for any possible solutions but found nothing specific. I did see some comments on parallax issues. I tried everything I could think of and finally resorted to sending it to Sony for repair. I am still waiting to get it back from Sony but the repair only cost $108.00 including return shipping. Sony called me last night and informed me of the progress. It was a little hard to understand the gentleman but he said it was something to do with a "shooter" part. My recommendation is to send it to them for repair.
Sony Alpha... | Answered on May 09, 2013
a firmware update error appears to have trashed your main circuit. usually this requires replacement of the circuit and initialization of the new circuit and downloading of data for it will work, which requires software not available from Sony. I am afraid from what you say this sounds like a factory repair - though I would argue with them that you did everything right and they ought to fix it for free
Sony Alpha... | Answered on Jun 04, 2012
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101'';';
Sony Alpha... | Answered on May 02, 2011
There are numerous things that can cause a lens error, and none of them good. The camera is almost new and shouldn't be experiencing any of these messages. You should contact Sony support and see what can be done. Here is their support site:
http://esupport.sony.com/
If they can't help you resolve this, and won't honor any kind of warranty, the following site details things you can try to correct this problem:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
There are tiny gears inside the lens assembly, and a focusing ring, and any speck of dirt or dust or lint can jam one up, causing a lens error. You can try to spray some compressed air ($4 at Walmart) inside the lens assembly, while it's extended, and hopefully free it up.
Hopefully Sony will help you out, and allow an exchange.
Sony Alpha... | Answered on Jan 02, 2011
An SD memory card usually has a little white slider on the outside of it. I says in small letter, with a little arrow "LOCK" . Push the slider in the opposite direction of the arrow i.e. to unlock it.
If this is the case, then the camera should be able to communicate and write to the card.
There is also the possibility that the device in the camera which detects this slider is damaged. In that case the camera should be repaired. I think, though you will be OK moving the slider.
I hope this has helped you.
Happy New Year,
Best, Mark
Sony Alpha... | Answered on Jan 01, 2011
can you tell me how to solve memory card error for Sony SLR a230? they asked me to format it but i've taken thousands pictures. please and thank you
Sony Alpha... | Answered on Oct 16, 2010
Unfortunately this is a Japanese spec walkman and there is no option to change the language!
you could try to flash (replace) the firmware from an English spec walkman but if not done properly that could damage it and make it unusable!
I would just live with it and possibly learn Japanese ??
Sony Cameras | Answered on Jun 09, 2020
You have to format SD cards in the camera they are installed in. The operating systems are proprietary to each make, and sometimes even a specific model. Read this
http://www.peachpit.com/articles/article.aspx?p=2022659&seqNum=4
SONY NEX F3 "writing to memory card unable to operate" please help ...
https://www.dpreview.com > ... > Sony Alpha / NEX E-mount (APS-C) Talk
Jul 8, 2013 - 6 posts
there is a problem with my sony nex f3, when im taking a picture and then ... the card in a computer, format it, insert it in the camera and format it ... WHERE IS FORMAT SD CARD LOCATED: Sony Alpha ...
Mar. 27, 2017
REINSERT THE MEMORY CARD: Sony Alpha / NEX E ...
Mar. 9, 2016
Sony A7 : Unable to read memory card. Reinsert Memory ...
Jul. 17, 2017
memory card error?: Sony Alpha / NEX E-mount (APS ...
Aug. 19, 2010
More results from www.dpreview.com
Formatting Your Memory Card ' Getting Started with Your ...
www.peachpit.com > articles > article
Feb 27, 2013 - Jerod Foster covers a few things you need to know before firing up your Sony NEX-6, including choosing and formatting your memory card, ...
Sony Cameras | Answered on May 25, 2020
Not unless your willing to do it yourself.
Tweezers to pick at it or a precision screwdriver set to dissemble the unit and remove the card and reassemble.
Good Luck
Mr.Mike
Sony Cameras | Answered on May 21, 2020
Sony Alpha DSLR-A230 Digital Camera Logo
23 questions posted
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
sony dslr a230 no power after firmware
  • Cameras
