20 Most Recent Vivitar ViviCam 8018 Digital Camera Questions & Answers
Trouble registering my vivitar 8018
Not sure I understand what you mean, but if the Vivitar site can't help you I can't. ViviCam 8018 Digital Camera Vivitar
12/27/2014 11:36:14 AM • Vivitar ViviCam... • Answered on Dec 27, 2014
How to unprotect a sd card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
5/19/2014 11:18:38 AM • Vivitar ViviCam... • Answered on May 19, 2014
2answers
Hi I am trying to find out how to stop my
First check your lens and make sure it is clean. Second, try taking a photo outside in daylight using your timer, with your camera sitting on a solid stable surface. If the photos are still blurry, try setting your camera options to factory default and redo the same test. If the photos are still blurry, I would suspect the camera is defective.
5/1/2014 6:41:20 PM • Vivitar ViviCam... • Answered on May 01, 2014
Sensor fail
If the camera is under warranty I'd take it in to get it repaired. Could be a failed light sensor. Nothing you can fix unless you are an electrical engineer.
11/16/2013 9:02:35 PM • Vivitar ViviCam... • Answered on Nov 16, 2013
4answers
Will pictures stay on a folder when erased from camera
Yes, as long as they are not overwritten by new data, you are able to recover deleted pictures from camera. you can follow this tutorial that helped me beforeHow to recover deleted photos from Camera
10/12/2013 1:24:54 AM • Vivitar ViviCam... • Answered on Oct 12, 2013
My camera is no longer working even though i put new baterrys in why?
buy a new one
12/31/2012 10:15:58 PM • Vivitar ViviCam... • Answered on Dec 31, 2012
Wont turn on.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
11/10/2012 9:51:18 PM • Vivitar ViviCam... • Answered on Nov 10, 2012
Sensor failure
I suggest visit your local photo techinical and try is underwarranty even.
8/9/2012 3:22:02 PM • Vivitar ViviCam... • Answered on Aug 09, 2012
Is there a vidio cam on this vivicam
There is. It's not a particularly good one, compared to a dedicated video camera. It also does not record sound. You can add a soundtrack using video editing software on a computer, but you cannot record one on this camera.
7/11/2012 7:40:54 PM • Vivitar ViviCam... • Answered on Jul 11, 2012
Donload viviam8018 manual
You may download a copy of the manual here.
5/12/2012 5:58:29 AM • Vivitar ViviCam... • Answered on May 12, 2012
Download manual
You may download a copy of the manual here. How fast the download happens is dependent on, among other things, the speed of your internet connection.
5/12/2012 5:57:54 AM • Vivitar ViviCam... • Answered on May 12, 2012
How to work the video on this camera
The video instructions begin on page 23 of the manual.
2/29/2012 7:20:11 AM • Vivitar ViviCam... • Answered on Feb 29, 2012
No flash
Make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the USB socket. Set this switch to the mountain position. Also bear in mind that the flash is for still photos only, not for videos.
2/29/2012 7:18:36 AM • Vivitar ViviCam... • Answered on Feb 29, 2012
How do you get the flash to work on a vivitar 8018
Make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the USB socket. Set this switch to the mountain position.Also bear in mind that the flash is for still photos only, not for videos.
2/29/2012 7:17:31 AM • Vivitar ViviCam... • Answered on Feb 29, 2012
There is nothing in the
2/29/2012 7:13:48 AM • Vivitar ViviCam... • Answered on Feb 29, 2012
I lost my CD to install it can I install it online
You can get the Vivitar software here. Click on the "Vivitar Experience Software" link.You don't need to use the Vivitar software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
2/29/2012 7:10:34 AM • Vivitar ViviCam... • Answered on Feb 29, 2012
I cant get the flash to work
Makes sure you're not in the macro mode. There's a slide switch on the end of the camera, near the USB socket. Set the switch to the mountain position.Also bear in mind that the flash is for still photos only, not for videos.
2/29/2012 7:08:04 AM • Vivitar ViviCam... • Answered on Feb 29, 2012
How do i turn flash on
Makes sure you're not in the macro mode. There's a slide switch on the end of the camera, near the USB socket. Set the switch to the mountain position. Also bear in mind that the flash is for still photos only, not for videos.
2/29/2012 7:06:51 AM • Vivitar ViviCam... • Answered on Feb 29, 2012
How do you turn the flash on?
2/29/2012 7:05:56 AM • Vivitar ViviCam... • Answered on Feb 29, 2012
Do i need a charger
The 8018 uses standard AAA batteries. If you use disposable batteries then you don't need a charger. If you use rechargeable batteries then you do need a charger as the camera does not charge batteries.
2/29/2012 7:02:29 AM • Vivitar ViviCam... • Answered on Feb 29, 2012
Vivitar ViviCam 8018 Digital Camera Logo
156 questions posted
Top Vivitar Cameras Experts
David Shaub
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
will pictures stay folder when erased
  • Cameras
