20 Most Recent Canon Powershot A480 - Silver Digital Camera Questions & Answers
2answers
My Canon Powershot A480 says the SD card is full even though it is not. How do I fix this?
You most likely have a problem with the memory card reader inside the camera. Have it repaired,it's not expensive at all and it's the only option for correcting this problem. This place is excellent and the most affordable for Canon Powershot repairs (it's all they work on): www.CamerasAndParts.com Go to their site and you should find the email address for them. Send them an email, they'd be the ones to help you with this problem since it's a Canon. Good luck
11/24/2014 6:02:00 PM • Canon Powershot... • Answered on Nov 24, 2014
How to use as webcam cannon A480
Take a look at this.
1/2/2013 4:53:41 PM • Canon Powershot... • Answered on Jan 02, 2013
0answers
Saying memory card error card
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
7/8/2011 12:27:44 AM • Canon Powershot... • Answered on Jul 08, 2011
Cannot delete videos from Canon
Unprotect it first.
Full details are in the "Protecting images" section of the manual (page 92 in my copy). If you need a manual, you can download one from the manufacturer's web site at
http://gdlp01.c-wss.com/gds/7/0300001857/01/PSA480_CUG_EN.pdf
6/20/2011 5:45:08 PM • Canon Powershot... • Answered on Jun 20, 2011
The lens on my canon
Hello
You especially might consider this if the lens barrel appears obviously damaged, bent, or crooked such as from a fall. Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
hope it helps, if not take camera to the technician, if so
DO RATE THE SOLUTION
Good Luck
1/1/2011 7:57:21 AM • Canon Powershot... • Answered on Jan 01, 2011
2answers
Camera indicates card locked! no
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
12/17/2010 6:00:13 AM • Canon Powershot... • Answered on Dec 17, 2010
Canon PowerShot A480 won't take photo.
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
6/20/2010 7:38:50 AM • Canon Powershot... • Answered on Jun 20, 2010
I cannot connect to my camera
connect the camera and the push the switch by which u see the photos on the camera screen
2/17/2010 1:31:08 PM • Canon Powershot... • Answered on Feb 17, 2010
I am looking for an english language user guide
You can download the required manual from the manufacturer's website by clicking this link
Direct download link:
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
1/14/2010 11:44:43 AM • Canon Powershot... • Answered on Jan 14, 2010
Power button sticks down
It should be under warranty if it is less than a year old and purchased from a reputable dealer selling USA product. Send it back. If something was spilled on it then that would be why the button sticks and there would be no warranty for that, unless you purchased a service contract that cover liquid damage.
11/21/2009 7:26:35 AM • Canon Powershot... • Answered on Nov 21, 2009
It doesnt came on
Fixing a Lens Error on a Digital Camera This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
10/21/2009 11:31:20 PM • Canon Powershot... • Answered on Oct 21, 2009
Request for conversion of manual from japanese to english
Check this Link to download the Manual.
http://files.canon-europe.com/files/soft32720/manual/PSA480_CUG_EN.pdf
Good Luck!!!!!!!!!!!!!!!!
9/13/2009 11:03:41 AM • Canon Powershot... • Answered on Sep 13, 2009
I have a new powershot A480 but do not have a
manuals for your model are available on the canon site for your region under their support button
8/15/2009 8:07:23 AM • Canon Powershot... • Answered on Aug 15, 2009
4answers
How to use and do photography on canon power shoot sx 60sh?
I was extremely lucky to have many talented and generous photographers take me under their wing to show me the ropes. Without their valuable advice there is no way I would have become the photographer I am today. The Best Candid Wedding Photography Chennai as NDS photography in Chennai Welcome To NDS 24x7 Studio nds (4)-b2fh1usk30gaat4h2ysqy3a5-4-0.jpg
5/9/2022 5:43:27 AM • Canon PowerShot... • Answered on May 09, 2022
My Canon pc1234 keeps saying I have a memory card error. How come?
The card may be corrupted and unusable. Try with a new SD Card. If that doesn't work, you need Canon Service. Try formatting it in the computer, add images and see if you can see the images in the camera.
10/1/2021 8:49:37 PM • Canon PowerShot... • Answered on Oct 01, 2021
My Canon A250 batteries are getting drained when i switch on
If the batteries are the same age as the camera, they are probably worn out. Try replacing them.
1/8/2018 4:17:55 PM • Canon PowerShot... • Answered on Jan 08, 2018
Memory card error Canon ELPH530HS
What did the error prompts?
12/22/2017 3:38:57 AM • Canon PowerShot... • Answered on Dec 22, 2017
Orange light flash sd550 750
Settings menu to off the option
11/17/2017 10:50:54 PM • Canon PowerShot... • Answered on Nov 17, 2017
2answers
How do I retrieve pictures after they have gone missing from my card?
So the pics vanished from the memory card, right? Perhaps you can insert the card to your computer and try a photo recovery tool on it. Give this app a try if you're a Mac user. Recover Digital Photo Music and Video on Mac OS
8/17/2017 8:45:03 AM • Canon PowerShot... • Answered on Aug 17, 2017
Canon Powershot A480 - Silver Digital Camera Logo
16 questions posted
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
canon powershot a480 says sd card full
  • Cameras
