20 Most Recent
HP Deskjet D4360 InkJet Printer Questions & Answers
Print wirelessly
It depends on you operatng system- you have a mac or a PC? Which version of wondows or OSX?
Low ink indicator
Turn the printer on.
Lift the lid that covers the print-head mechanism.
Wait for the print-head to slide to the position at which the ink-cartridge(s) can be removed.
Press down on the ink-cartridge, to "unlock" it from the print-head.
Gently remove it.
Insert a new/refilled ink-cartridge, and "lock" it into place.
Print a "test" page.
Refilled ink cartridge shows 0 level after
There is no easy fix for restoring the ink levels on this kind of printer, but if you just want to end the annoying alert about ink level you simply have to do the following:
- Go to Start
- Printers
- Right click on your printer
- Properties
- Ports
-and here you need to tick off the bidirectional support item.
Now you wont get more annoying messages from the printer.
Hope this helps!
Regards!
I can't get labels to
All printers have a "non-printable area" at the four edges of the sheet. If you labelling program doesn't allow you to specify how wide this area is and subtract it from the layout, you'll have difficulty printing inside the boundaries of the first and last label across the sheet. Similarly the top and bottom labels might not be complete.
Cantaflex
