20 Most Recent AudioBahn AWES15P 15" Subwoofer Car Speaker Questions & Answers
i dont ever get tired of saying it LOL A2300HCX audiobahn
AudioBahn... | Answered on May 11, 2010
Contact company the can send you diagrams or go to a stero stop they should be able to help because some shop have wire diagrams for best way to get the most thump in you r trunk.Make sure you know the ohms your subs is 1-2-4 ohms.Should say on the back of your sub and how many contacts are on in two or four.
AudioBahn... | Answered on Mar 03, 2009
parallel wiring (if your amplifier is 1 ohm mono stable)
All positives together and all negatives together.
If your amplifier is not 1 ohm mono stable you will need a series/parallel which is a little more difficult.
Here is a wiring link.....
http://www.the12volt.com/caraudio/woofer_configurations.asp
AudioBahn... | Answered on Dec 21, 2008
Hello William Novelli, if it would be compatible, but you should control the order of the connections, they can vary
I send you the link to download the manuals of both models and compare the connections, if you find it complex, consult a specialized technical service
I hope you find it useful
Regards Franco Dosil
Hola William Novelli, si seria compatible, pero deberas controlar el orden de las conexiones, pueden variar
Te envio el link paravque descargues los manuales de ambos modelos y compares los conexionados, si te resulta complejo, consulta con un servicio tecnico especializado
Espero te resulte util
Saludos Franco Dosil
https://manualmachine.com/audiobahn/aeq7/18414-user-manual/
https://manualmachine.com/audiobahn/aeq8/18268-user-manual/
https://www.manualslib.com/manual/211695/Audiobahn-Aeq6q.html
AudioBahn Car... | Answered on Sep 13, 2019
as your sub is only rated to 400w rms simply connect the sub to either a or b channel outputs you may wish to use an rca splitter before the amp to feed both left and right audio channels into a single channel on the amp. WARNING connecting both channels on the amp to the sub will overload the sub and possibly blow it up so i highly recommend not doing so.
AudioBahn Car... | Answered on Jun 03, 2018
i was not able to locate a manual but i did find some interesting information that hopefully may help,
The AudioBahn AW1000X Car Subwoofer Features: dual 4-ohm voice coils, non-pressed pulp cone, huge foam surround, frequency response 23-500 Hz, power range 50-600 watts RMS (300 watts per coil), peak power handling 1,200 watts, sensitivity 91.1 dB, top-mount depth 5-1/4" ,sealed box volume: 0.4-.95 cubic feet, ported box volume: 1.632 cubic feet.
i'd need more info but from what you've stated, sorry to break it to you but it sounds likely you've incorrectly wired you speakers and blown your amp. this will prove no doubt an expensive mistake and learning exercise.
to drop the amp load to 1 ohm you need to divide the output signal path and the best way is by wiring a second woofer in parallel as seen in the ideal diagram attached this has the desired effect of doubling the volume .
since 2 ohm divided by 2 is 1 ohm load connected to your amp.
so the short answer is no you can't do that with a single woofer
Generally there are 2 parts to this problem
part 1
input signal as these woofers are just subs remember to give them a low line in signal before the amp (see diagram) i like to use rca low pass crossover filters from harrison labs (see link)
part 2
is the wiring configuration of the 2 woofers by wiring them in parallel as shown in the diagram you reduce them to a 2 ohm load for your 2 ohm amp meaning you'll get max loudness and efficiency
Harrison Labs FMOD Inline Crossover Pair 100 Hz Low Pass RCA Shipping is...
unfortunately if you only have the one woofer there isn't really any safe way to do so but if you had a pair of woofers you could in theory wire them in parallel thus creating only a 3 ohm load but your amp must be able to work at such low ohms otherwise you WILL blow up your amp.
Car Audio & Video Logo
4 questions posted
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
Alphanso Tee
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • AudioBahn Car Audio & Video
Most Popular Question
best amplifier audiobahn awes15p
  • Car Audio & Video
