20 Most Recent Apple Refurbished MacBook 2.4GHz Intel Core 2 Duo - Aluminum Mac Notebook Questions & Answers
I have just hooked up an external monitor (LG
  1. When you connect an external monitor to your MacBook (or PowerBook, for that matter), you can combine your MacBook's LCD and your external monitor to create one big monitor. That means when your mouse pointer goes off the edge of one, it will appear on the other. Open the Displays Preference Pane to configure the resolution and orientation of the two monitors. This type of configuration works well when you want to keep your main work on your larger external display, but still keep things like IM, iTunes, and email constantly visible on the smaller laptop LCD.
  2. Some windows act like they don't want to be dragged on to your external monitor. If a windows is being stubborn, try dragging it up to the menu bar, and keep dragging, even if stays stuck below the menu bar. Sometimes once you have dragged it far enough that it has room to render the entire window, it will jump to the other monitor (Terminal used to have this problem, but Apple fixed it some time ago). If that doesn't work, try dragging it from a corner of your monitor. My Adium contact list doesn't seem to want to live on my external monitor, but I can coerce it up there by dragging up from either corner.
  3. When your laptop is open, you can't switch to using the full resolution of an external monitor. I have no idea why, but it's a fact of life for MacBook users. You can use both displays in "extended" mode, or you can mirror your MacBook's display (which most likely doesn't use the full resolution of your external monitor), but you can't switch to using only the external monitor. Very strange.
  4. If you close your laptop, you can actually get the full resolution of your external display. Put your MacBook to sleep, connect your external display and an external monitor, and wake the computer up by pressing any key. You will have full use of your external display while your laptop is closed.
  5. If you really want to have your MacBook open while only using an external display, after following the procedure above, you can open your MacBook, and it's screen will remain off, which means you can still use the MacBook's keyboard and trackpad. Why you can't get into this mode using F7, I have no idea. This is a good technique for allowing some heat to dissipate while still using an external display so the lid of your MacBook doesn't melt or warp.
  6. You can boot your computer using just an external display. Just connect your external display, open the lid, hit the power button, and close the lid again immediately.
  7. In order to output only to an external monitor, you have to have the power cable connected. I tried for several minutes yesterday to get my MacBook to wake up with an external keyboard and monitor before unpacking my AC adapter from my backpack, and it wouldn't work. It took me a while to make the connection (no pun intended), but I eventually discovered that with the power cable attached, everything works as expected.
8/6/2009 5:06:05 AM • Apple... • Answered on Aug 06, 2009
5answers
How do I link Apple Music to echo
Turn Bluetooth on and pair with your echo
3/21/2024 4:31:24 PM • Apple Computers... • Answered on Mar 21, 2024
2answers
I am a new customer t o Netflix. I joined yesterday and got number. I am on the net at home and have Apple TV. How to I start watching Netflix on Apple TV?
Connect the Apple box to the TV with a cable. Using the TV remote select the input port you connected the apple box to. ie HDMI. Click the center button on your apple remote. You should see a Netflix icon. Select it and then log in to your Netflix account
1/18/2024 2:28:12 AM • Apple Computers... • Answered on Jan 18, 2024
3answers
I dropped my mac lap top and the screen is a bit fuzzy, how can I fix it?
Thank for contacting Fixya, I will be glad to assist you. You cannot, without having a diagnostics performed by a certified Apple technician or Apple Authorized Service Provider. You may have damaged the video graphics card on the main logic board of your MacbookMacbook Pro.Unless you have knowledge on how to go in and physically troubleshoot this geniune hardware issue, I would recommend you do you to your local Apple retail store Genius bar, or Apple Authorized Service center near you and have your Macbook looked at.Just for your reference, I have taken the liberty to provide the store locator links to your local Apple Retail store as well as a general store locator for locating any local Apple Authorized Service center in your area.Apple Retail Store(Genius bar - need to set appointment via this website link, if planning on visiting Apple store of choice in your immediate area)Apple Authorized Service ProviderYou don't want to keep turning on the Macbook until you have it checked because it could affect more than just the video graphics card.Regards,-The MacTechTrainer.
12/28/2023 6:55:45 AM • Apple Computers... • Answered on Dec 28, 2023
11answers
Isn't there any manual procedure to migrate apple mail to windows outlook?
Unfortunately, there is no way you can transfer your apple mail email database to windows outlook manually. You will have to take help of the third party tools that you are talking about. Here is one I feel is much superior to others and provides quick and hassle-free migration from apple mail to windows outlook. Apple Mail to PST Converter
4/11/2023 9:39:02 AM • Apple Computers... • Answered on Apr 11, 2023
My I pad is gone. Sister gave me a used apple 1. How do I set up apple I'd and password
if it doesn't have an existing apple id on it can set it up with yours or use iTunes on your computer and restore it to your existing account
4/8/2023 4:09:31 PM • Apple Computers... • Answered on Apr 08, 2023
I have a Sanyo Xacti 10 MP that records with date and time but when I put the SD card in my Apple laptop and download the videos, the date and time seems to not stay on the videos.
The date and time information may not be embedded in the video file itself, but rather in the metadata of the file. When you transfer the video from your camera to your computer, the metadata may not be transferred along with the video. To preserve the date and time information on your downloaded videos, you can try the following:
  1. Use a video player that displays metadata: Some media players, such as VLC media player, allow you to view the metadata of a video file. If the metadata contains the date and time information, you may be able to view it using such a player.
  2. Transfer the video using a program that preserves metadata: Some file transfer programs, such as Image Capture on Mac, will preserve metadata when transferring files. You may try using such a program to transfer your videos.
  3. Use a metadata editor to add date and time information: You can try using a metadata editor, such as ExifTool, to add the date and time information to your video files.
It's worth noting that not all video file formats support metadata, so depending on the format of your video files, it may not be possible to preserve the date and time information.
3/20/2023 10:55:30 PM • Apple Computers... • Answered on Mar 20, 2023
2answers
How to factory reset iMac without login or keyboard?
To factory reset an iMac without a login or keyboard, you can try the following steps:
  1. Boot the iMac in Target Disk Mode: Connect the iMac to another Mac using a Thunderbolt cable. Power on the iMac while holding down the T key. The iMac should appear as an external disk on the other Mac.
  2. Reinstall macOS: Open the Disk Utility app on the other Mac and select the iMac disk. Choose "Erase" and follow the on-screen instructions to erase the iMac's drive. After erasing, quit Disk Utility and follow the on-screen instructions to reinstall macOS.
  3. Restore from Time Machine Backup: If you have a Time Machine backup of the iMac, you can restore the backup to the iMac after reinstalling macOS.
If these steps don't work, you may need to seek assistance from an Apple Store or a professional repair service.
2/24/2023 7:36:24 PM • Apple Computers... • Answered on Feb 24, 2023
I have a new MacMini 2021 Monterrey O/S. I use Zoom but my Gear Head Webcam F#2 4.8mm is not on or is not connecting? IS it compatible with Apple Monterrey O/S?
It's possible that your Gear Head Webcam F#2 4.8mm is not compatible with the new MacMini 2021 running the Monterrey operating system (macOS Monterey). The best way to check for compatibility is to visit Gear Head website and check for the compatibility list for the webcam with the MacMini 2021 running the Monterrey operating system. If the webcam is not on the list, it's possible that it may not be compatible with the new operating system. If the webcam is not compatible with the new operating system, it may not be able to connect to the MacMini or be recognized by the Zoom app. Alternatively, you can try connecting the webcam to the MacMini using a USB-C adapter and see if that resolves the issue. You may also want to check if there is any new firmware update available for the webcam or the Zoom app that might resolve the issue. If the issue still persists, it would be best to contact Gear Head customer support for further assistance and check if there is a way to make the webcam compatible with the new operating system or if there is any other solution that can be provided.
1/12/2023 12:36:43 PM • Apple Computers... • Answered on Jan 12, 2023
2answers
McGourment App Will not Open ?
The developers do this on purpose. They give you the free version to build up subscribers and improve with updates. Then they bring out the paid version and forget about the free version. https://apps.apple.com/us/app/macgourmet-deluxe-4/id726472926?mt=12 There appears to be an Upgrade Migration Tool. https://marinersoftware.deskpro.com/kb/articles/how-do-i-upgrade-to-macgourmet-deluxe-4-from-my-current-version and you end up with this https://marinersoftware.com/product/macgourmet-deluxe/ ..
1/6/2023 10:21:24 AM • Apple Computers... • Answered on Jan 06, 2023
2answers
Gamestop app
The GameStop app looks like it is only for window machines. At least according to the website. Download GameStop PC App At GameStop com
12/13/2022 10:08:18 AM • Apple Computers... • Answered on Dec 13, 2022
2answers
Unlock MacBook pro
On the newer macs, you can hold down D while booting which will take you to diagnostics mode. There you can reset the password. For older systems, you will need boot media.
12/7/2022 8:01:52 AM • Apple Computers... • Answered on Dec 07, 2022
3answers
Setting up Apple music on Echo dot
You Can Now Ask Alexa to Play Apple Music with Amazon Echo Controlling home by voice is going to be a lot of fun. Amazon Echo, a nine-inch black cylinder, is such a smart speaker that connects to the voice-controlled intelligent personal assistant service Alexa. You can use Amazon Echo to do certain things like play music, set alarms, make to-do-list, order items from Amazon, and control a smart home. To play an audio? It becomes extremely simple when having an Amazon Echo. Instead of tapping here and there on the phone, you only need to hook up your account to the Echo, then simply ask Alexa to play whatever you want. Unsurprisingly Echo includes Amazon's own music services, as well as some others such as Spotify, Pandora. So what about other streaming services such as Apple Music? Does Amazon open to have Apple Music on the Echo? Is it possible to stream Apple Music to Amazon Echo? The post would answer these questions and show you how to play Apple Music on Amazon Echo by asking Alexa.
Apple Music does not come to Amazon Echo
Amazon Echo is capable of playing music from other sources and streaming music from various services, including Spotify, Pandora, iHeartRadio, and Amazon Music. How about Apple Music? Unfortunately there is no support for Apple Music at the moment. When will Apple Music come to Amazon Echo? According to a report from Bloomberg, Amazon's Dave Limp was quoted as saying, "We'd love to have Apple, but they're not super big." Perhaps Amazon thought Apple Music is not quite big enough to consider integration even though Apple Music has already racked up more than 20 million paid subscribers in two years since announced in 2015.
Use the Amazon Echo as a Bluetooth speaker to Play Apple Music
Although Apple Music is not native supported by Amazon Echo, Apple Music subscribers can still stream songs through the device, it's just that they'll need to pair their iPhone or iPad to the Echo and stream it from their phones instead. For people who also want to play music from iTunes library with Amazon Echo, they should also make it via Bluetooth. In this way, Amazon Echo is used as a Bluetooth speaker which does not make it unique. Here are the steps to stream Apple Music on Amazon Echo via Bluetooth:
  • Go to Settings. Then, tap on Bluetooth and toggle the button to the on position.
  • You'll now see your Amazon Echo device listed under My Devices. Tap on it and it'll pair with your phone or tablet.
  • Navigate to your Music application where your Apple Music are accessible and start playing them.
Now, Apple Music songs should be heard coming from your Amazon Echo device instead of your mobile device speaker. Link Apple Music to Alexa on Amazon Echo Pairing your device with the Echo using Bluetooth and selecting it as the audio output is an option to stream Apple Music from your iPhone. It is not a bad solution. But if what you intend to do is get Apple Music on Amazon Echo by using Alexa, then uploading Apple Music songs to Amazon is a great way. You can upload your Apple Music collection to your music library on Amazon and then stream the Apple Music through your Alexa device. Before importing Apple Music to Amazon, we still have one thing to solve. That is, removing DRM from Apple Music or the songs from Apple Music could not be recognized and uploaded to Amazon successfully. Here we use Apple Music Converter to convert Apple Music tracks and playlists to plain DRM-free MP3 to walk you through. $39.95 Buy Now (Mac) $39.95 Buy Now (Windows)Click the + button on the top or anywhere on the center to open the Add window. The Apple Music converter detects the whole iTunes music library automatically, so that you could simply select any playlist you saved or any track you prefer, then press OK to confirm. The chosen Apple Music songs are displayed on the main panel of the Apple Music Converter. Click the Gear button on the top right to open the Preference window where you could set the output format, audio quality, conversion speed and the way to organize the output file. For example, choose MP3 as output format, 320 kbps as output audio quality and 20x conversion speed. After pressing CONVERT button on the bottom, the Apple Music songs are being converting to MP3 at a very fast speed with high quality one by one. The output folder destination can be found by History > Folder. The songs from Apple Music are now DRM-free and could be able to upload to Amazon for playback via Alexa.
Skill to Stream Apple Music on Amazon Echo with Alexa
Upload the converted Apple Music songs to My Music on Amazon from your Mac or PC, when finished, you can ask Alexa to play your Apple Music songs on Amazon Echo and control playback with simple voice commands.
  • Run Amazon Music app on your PC or Mac and log in your ID.
  • Drag and drop files from the folder where stored the converted Apple Music songs into the Upload selection.
You can see uploaded music, and music that's uploading, by clicking the Uploaded filter in the left navigation sidebar. Once the Apple Music songs are imported to Amazon Music, you can play them on Echo or Echo Show speakers with simple voice command via Alexa. Speak "Alexa, pause" or "Alexa, next" and the music will pause or skip to the next song. You can also ask for Alexa to play music by genre, decade, mood, tempo, activity, and even lyrics. Amazing!
11/22/2022 9:59:28 AM • Apple Computers... • Answered on Nov 22, 2022
2answers
9348582838 i want name and address of this
is this a IP number? if it is an IP number you can get the info you want in the terminal window and write the word dig *number or address*
11/12/2022 4:48:46 AM • Apple Computers... • Answered on Nov 12, 2022
2answers
I get a message that my HP 5500 is not connected to my new iMac but the printer says it is connected. How to solve?
The printer says that it is connected correctly to the router because the router is aware of it and has assigned to it an IP address on the network. The computer on the other hand does not know that there is a printer. Not finding one (or not knowing where to look for it) the computer reports that the printer is offline. You must install the printer drivers on the computer.
9/20/2022 8:10:28 PM • Apple Computers... • Answered on Sep 20, 2022
4answers
How do I move or transfer Apple mail emails?
There have been similar queries, have a look:-Why can't I important mail from Apple Mail to Outlook 2011?Apple mail to outlook 2011I hope you will find what you are looking for.Thank you
5/30/2022 10:04:28 AM • Apple Computers... • Answered on May 30, 2022
3answers
Apple Router Customer Service pHoNe #{+l855^26O^*OO64} nUmBeR UsA
Jenis judi terpercaya dirasa mampu memberikan keuntungan judi yang lebih baik. Anda bisa mendapatkan kepuasan bermain dengan beragam keuntungan yang lebih baik. Dengan cara yang tepat, Anda bisa menemukan situs judi terpercaya dengan mudah. Salah satunya hanya di situs judi online http://www.poker-lounge99.asia yang bisa anda mainkan dan pastinya terpercaya!
5/13/2022 10:48:03 AM • Apple Computers... • Answered on May 13, 2022
2answers
Why did I receive an apple id verification code text message on my boost mobile phone
you would only usually receive an apple id verification code when creating anew apple id or changing your apple password. possible either someone has changed your apple password so best to check if you have one that it is still the same. or someone put the wrong mobile number in when setting their up. the verification text is part of the security hope that this helps
4/28/2022 6:21:01 AM • Apple Computers... • Answered on Apr 28, 2022
Apple Refurbished MacBook 2.4GHz Intel Core 2 Duo - Aluminum  Mac Notebook Logo
1 questions posted
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Computers & Internet
Most Popular Question
just hooked up external monitor lg
  • Computers & Internet
