20 Most Recent Samsung Propel Pro SGH-i627 Cell Phone Questions & Answers
Starting from the home screen, go to 'Start > More > Settings > Connections > GPRS' and, if there are already data filled in there, check them according to your carrier's instructions. Otherwise, press 'Menu > Add' and fill in the required data (basically Description - a name you give to the connection; Connect to - select GPRS; Access Point - the APN itself; Username and Password (all three provided by your carrier).
By the way, such informations can be found on pages #85 and #86 of your phone's user manual. In case it happens to be missing, feel free to download it from this location
Anyway, please, let me know if you need further informations.
Regards,
Carlos.
Samsung Propel... | Answered on Nov 13, 2012
Regards,
Carlos.
If the phone locked to a particular network then you need to unlock the network lock. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
Samsung Propel... | Answered on Aug 18, 2011
I got my Samsung mobile codes from here @ http://www.mobile-unlocker.com/ - This is an unlocking website. Please view the website to get more info
Samsung Propel... | Answered on Aug 14, 2011
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Samsung Propel... | Answered on Jun 14, 2011
TEMPORARY UNLOCK: Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones: #*7337#
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100) To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Samsung Propel... | Answered on May 02, 2011
Unlocking your nokia is very easy at www.mobile-unlocker.com. I unlocked my mobile there and got the codes quickly. Then provide very good service.
Samsung Propel... | Answered on Mar 05, 2011
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website http://www.theunlockarena.com/unlock-your-phone/rs13wp2/
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Samsung Propel... | Answered on Feb 16, 2011
Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider. To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use the SIM cardwith a different phone provider, Please click on this link and follow myinstructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB sites - http://www.unlock-free.com http://www.unlock-zone.com/ http://www.unlocking.com/
Samsung Propel... | Answered on Feb 05, 2011
Unlock your cell phone 1. Power up your phone with your new unaccepted SIM card in. 2. Your phone should prompt for your unlock code. 3. Enter your unlock code. NEED IT FROM THE PHONE MANUFACTURER, CONTACT THEM ONLINE OR PHONE 4. phone may reboot and should be unlocked READY FOR USE!
Samsung Propel... | Answered on Jan 27, 2011
I have the same problem with the same phone.
I bought a Zeemote (bluetooth controller) which needs to have a .sis file installed on the phone, but the phone does not recognize the file type.
Please help.
As for mefonna's problem, I usually connect my phone to my laptop, go into 'My Computer' to access the phone and just transfer files (drag and drop) across directly to your phone from there.
There is also an app you could download called 'Bluetooth File Transfer' (which is free) to transfer files via bluetooth.
Samsung Propel... | Answered on Jan 25, 2011
hello sir
check your operator service.if all the things are fine then you can claim to the device dealer with your warranty.they will fix this or replace the set.be alert in this.ensure that this problem will never come in future.
thank you
Samsung Propel... | Answered on Dec 31, 2010
I had the same problem so I called AT&T and they solved the problem!!
1. Click 'Start'
2. Click 'Messaging'
3. Click 'Messages'
You should be in the screen where it shows all your text messages, not just one. If not, click the 'go back' key until you see the list of all your text messages.
4. Click 'Menu'
5. Choose 'Folders'
Your screen should be showing Deleted Items, Drafts, Inbox, Outbox and Sent Items folders.
6. Click 'Drafts' folder
7. Click 'Menu'
8. Choose 'Delete All'
After it has finished deleting, your screen should say To create a new message, etc.....
9. Click 'Menu' again
10. Choose 'Folders' again
11. Click 'Inbox'
12. Click 'Menu'
13. Choose 'Delete All' When its finished deleting it should say 'To create a new message, etc.....'
14. Repeat steps 9-13 for the Outbox and Sent Items folders as well.
15. Once you are SURE you have deleted all your messages in all the folders, click 'Menu', choose 'Folders', and choose the 'Deleted Items' folder
16. Once in the 'Deleted Items' folder, click 'Menu' and choose 'Delete All'
Since the Propel Pro is run by Windows, it's kind of like emptying the Recycle Bin on a computer. You delete the items and they go to a 'Deleted Items' folder, where you can 'Delete All' of the deleted items. I know it sounds confusing, but that is how you can get your 'Free Storage' back.
Once you've deleted your deleted items, (LoL) you can check your 'free storage' by going to "Settings" .. "More" .. "Memory Info" and the "Storage" (middle/orange folder) should have significantly gone down! I went from 89MB to 17MB!!
I really really hope this helps! Good Luck!!
If you still have storage problems, call 1-800-331-0500 and Dial 0 for customer service then dial 1 for technical support. They should be able to help you step by step! I really hope this helped! Good Luck again!!
-Denise
Samsung Propel... | Answered on Oct 07, 2010
you need to call the service provider of the phone. ex att and give them your imei, which you can get underneath the battery and theyll give you the code and how to enter it.
Samsung Propel... | Answered on Oct 03, 2010
Samsung Propel Pro SGH-i627 Cell Phone Logo
53 questions posted
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cell Phones
  • Samsung Cell Phones
Most Popular Question
unlock code samsung propel pro sgh i627
  • Cell Phones
