20 Most Recent Haier HL22F1 LCD TV Questions & Answers
Screen goes white and stays
LCD Screen panel all white screen,tv have sound?Yes,than the tv Tuner signal board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
10/21/2010 5:22:48 PM • Haier HL22F1 LCD... • Answered on Oct 21, 2010
How do i hook surround sound to my Haier TV L26B1120a
Are you using a cable or satellite box? If so you can connect the audio out jacks to the Surround Sound instead of the TV.
6/3/2018 5:48:48 PM • Haier HL... • Answered on Jun 03, 2018
I lost my tv remote of motel 21f17ss.can i get the
you have to go to your dealer to order a new one//
9/11/2013 12:44:16 PM • Haier HL... • Answered on Sep 11, 2013
HLH19W how can I Access a channel on my tv with
no no no no you cant..
9/10/2013 1:39:03 PM • Haier HL... • Answered on Sep 10, 2013
Code for haier
These are the setup codes for Haier: 0081 0216 0217 0157
10/26/2012 5:20:11 PM • Haier HL... • Answered on Oct 26, 2012
0answers
My Haier tv model LE55B1381 has an intermittent problem. It stops working i.e. power is ON but no sound or images. After an hour, it resumes working for a day then stops again.
Hi, please remove all accessories from your tv and monitor it to see if it runs into it's glitches again. Please also remember if you purchase a new remote when this issue started happening or did you start using direct tv ? You can also run a power cycle on the tv if this issue occurs again. Thank you.
11/23/2022 3:13:04 AM • Haier Televison... • Answered on Nov 23, 2022
2answers
How can I rotate the screen of my haier tv model LE32B7000
You should enter its service mode menu to do that. Visit these sites by a desktop computer and type in the model number of your set at the search window at the right side of the site to reach it very fast. Mobile view have no search box. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ https://electrohelponline.blogspot.com/
9/26/2022 5:05:59 PM • Haier Televison... • Answered on Sep 26, 2022
2answers
Haier TV has picture and changes channels fine, but the sound has gone. It is NOT that the Mute is on. The TV downstairs is fine so it is NOT the cable company.
You can try unplugging the TV for a bit to see if that resets it. Next check if the TV was set to use external speakers by accident. Finally, try a factory reset. Please add a comment with the model of the Haier TV for directions for checking the audio output menu and factory reset. I hope this helps. Cindy Wells (I had a different TV from a different brand that had no external audio port. It would sometimes lose audio on one channel or several channels. Unplugging the TV solved the problem; the factory reset option in the TV menu didn't resolve the issue.)
9/25/2022 4:33:25 PM • Haier Televison... • Answered on Sep 25, 2022
2answers
Am I suppose to put water into the Haier Standing Portable Air Conditioner?
Most air conditioners need water removed, not added. They act as dehumidifiers as they change the air temperature. What model air conditioner do you have? The Haier HPRD12XH5 has a blinking red LED with a triangle symbol to indicate the unit is flooded. Air conditioners can also fail if there is a coolant leak or the room is too cool. If the removed water freezes in the air conditioner, it can damage the fan and cause the motor to overheat. The air cooling systems that need water added are "swamp coolers". That's the term I learned for the old-fashioned fan + ice/water cooling systems that work well in low-humidity environments. They'll make the area feel hotter in high humidity conditions. I hope this helps. Please add a comment with the model of your unit for further information. Cindy Wells
8/22/2022 1:04:03 AM • Haier Televison... • Answered on Aug 22, 2022
2answers
Do I need an HDMI cable for my Wii system to work on my Haier tv
Yes you do
7/14/2022 7:13:37 AM • Haier Televison... • Answered on Jul 14, 2022
I have a Haier tv with no remote. It was working fine, I'm located in Baja California and I VTV but I turned it on and it went straight to no signal I need to know what input to put it on.
Normally you need a remote to access the Input Source. All televisions need a remote! If you can access Input, just scroll through them one by one until you get the signal. Replacement remotes are typically $12 to $20. Some Haier as $31. Add your model number after the word 'Haier'. https://www.google.com/search?q=haier+tv+replacement+remote ..
5/25/2022 2:14:51 AM • Haier Televison... • Answered on May 25, 2022
Haier 55E3500 tv has sound, no picture or backlight
Your backlights have failed and need replacing, parts may be hard to find
3/10/2022 6:56:56 PM • Haier Televison... • Answered on Mar 10, 2022
2answers
New remote for haier tv does not work. Removed batteries and pressed every button 30 secs. Put batterirs back in still dors notwork
Remove the batteries of remote control and press the on/off button for 1 minute facing the remote towards tv set. Then put the batteries back and yesss!! It works ??
12/14/2021 7:24:06 PM • Haier Televison... • Answered on Dec 14, 2021
My haier tv shows Run Channel Auto Scan, but remote is not working to set it. What can i do?
If you don't have a remote, Go to the menu where it says run channel auto scan, hover over the run button and .(on the tv) press volume up, volume down, input and menu at the same time. This (depending on your model) should start the scan
10/23/2021 4:38:14 PM • Haier Televison... • Answered on Oct 23, 2021
Haier HL22F1 LCD TV Logo
3 questions posted
Top Haier Televison & Video Experts
Jaime Hernandez
Paul Bade
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
HL Haier
  • HL Haier
Most Popular Question
screen goes white stays
  • Televison & Video
