20 Most Recent
Intel DG41RQ Motherboard CPU Bundle - Pentium Dual Core E5200 2.50GHz Retail Processor Questions & Answers
E5200 drivers
Hello the drivers can be downloaded here:https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41RQBut first select your windows system.And heres the ram support:http://www.intel.com/support/motherboards/desktop/dg41rq/sb/CS-029920.htmYour mainboard supports DDR 2 ram, up to 8 gb.Please select a quality brand, the cheap ones does not last long.Good luck
I have a intel DG41RQ
I have a problem, when i connect usb mouse, keyboard, printer and scanner. USB work fine, but i connect my Q Mobile then driver not work properly... when i try it to another system Q mobile work fine.
Abdul Ahad AmmarHow to Lose Cheeks Fat
Please send me the address
Hi, Arihant Systems.... m.i road,304,s.s tower new colony ,m.i road ,Jaipur Rajasthan 302001.India
+91 141 510 1916
Lots of drivers are either
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
I want intel DG41RQI motherboard drivers CD, how?
You can download this driver cd from Many Website. If it is in Image File It Will Be Better. First Download the Image File. And Save It. If you try to open that file. It will Open with Nero Software. Automatically Nero Dialog Box Will Appear. Then Change into the "Current Recorder" Box. Just Select
Drive H:TSSTCrop CDDVDW SH-S223C (DVD) or I:HL-DT-ST DVDRAM CGH22NS50 (DVD). Then Burn. automatically it will change Program File Or Setup File. Then U Can Use That Dvd To As Driver Cd. Ok. Just try It.
Hi. Motherboard DG41RG, sound included.
a motherboard disc the sound drivers could be on it
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question mark? Right click to reinstall
drivers or uninstall
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar
if his does not fix the
problem
have you tried this control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer
make sure you have an earth
******** before touching any parts inside your computer
hope this helps
My Intel Board DG41RQ beeps
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
I need Intel Dg31Rq vedio
Here is the download page for the drivers for your motherboard. Choose your Operating system and download the Video drivers and chipset drivers.
How can i get get
Greetings - There is no Bluetooth built into the motherboard, so I can't imagine what drivers you are referring to? Perhaps you are referring to a Bluetooth device you want to use with the board? If so you would have to get the drivers from the device manufacturer.
The full spec sheet for the board is located here:
http://www.intel.com/Assets/PDF/prodbrief/DG41RQ-prodbrief.pdf
Regards,
Mikeywaf
