Hi
Check if the glow coil comes on. If not then take the back off the dryer, and you will see a part about an inch and a half long, by a half inch wide and it is white in color. That is the thermal fuse. Make sure the dryer is unplugged, and take the 2 wires off the thermal fuse, and put the terminal ends together, and put a little tape on it, so it does not hit metal, and then see if it works. If it does, don't run the dryer that way. The thermal fuse is the only thing stopping that dryer from burning down the house. If it does not work it will either be the igniter or the flame sensor. However there are various reasons as to why a gas dryer wont heat. Please check the bellow link to get a detailed idea related to your issue.which will help you troubleshoot your problem:-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#theresnoheat_gas
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
17 questions posted
1,329 Questions
1,410 Questions
750 Questions
524 Questions
182 Questions
