20 Most Recent
ASUS P5KPL-VM Motherboard Questions & Answers
The computer keeps restarting over and over
Have you tried to reseat the processor?
If that does not work, how many memory Sticks (RAM modules) do you have?
Since you have 4GB I assume you have more than one and it could be 2x2GB or 4x1GB
Try to remove all the RAM and try turning the computer on with just one Memory Stick.
Do this for all the RAM and all the Memory slots of the Motherboard to make sure that you don't have a faulty Memory Module or a faulty Memory Slot.
If nothing happens, check if you are using an Integrated VGA or a PCI/PCI-E video card.
Remove the card if you have one and try using the Integrated VGA because the GPU or the Memory of the Graphics adapter could be bad.
If still that does not work and the same problem happens then I'm sorry to say but your Motherboard is bad and it may just have to be replaced.
Hope this helps!
I need a schematic for motherboard
You will not be able to get a schematic for any motherboard; these are proprietary designs.
You can get a board layout from the ASUS site for any of their motherboards and documentation useful for setting up.
A hard-copy schematic would cover many square yards if all of the integrated components were broken down into individual parts since they number in the millions.
I cant install no virson
check your system bios if your installing a xp install you must set your advanced settings to ata... ahci will not install xp in fact thats the exact error you get when you try. windows 7 should be set at ahci and not on auto or compadable
Windows 7 compatibility?
Left 4 Dead System Requirements:
- OS: Windows Vista, XP or 2000
- CPU: 3.0 GHz P4, Dual Core 2.0 or AMD64X2 (or higher)
- RAM: 1 GB for XP / 2GB for Vista
- DISC DRIVE: DVD-ROM Drive
- HARD DRIVE: At least 7.5 GB of free space
- VIDEO: Direct X 9 compatible video card (Video card must be 256 MB or more and should be a DirectX 9-compatible with support for pixel shader 2.0)
- SOUND: Direct X9.0c compatible sound card
Vga
http://images.google.co.in/imgres?imgurl=http://www.blogcdn.com/www.engadget.com/media/2006/11/vga
Sound driver installation failed.
Browse the asus website that i can provide select if what type of operating system did you use.
http://www.asus.com/product.aspx?P_ID=i5ktecSJbqQKaa0x&content=download
Regards
PCmania
I cant get my pc to boot up at all, I switch on
Make sure that the moniter is securely plugged in, and the screws at the head of the moniter cable are screwed all the way in.
Also, if you modified or changed the video card of you computer, make sure that the video card is compatible
If you just got you computer, call the manufacturer to get shipped a new one, if yours is still under warranty.
