20 Most Recent Antec 430-Watt Power Supply Questions & Answers
At CompUSA, they sell an inexpensive power unit checker for around 10 bucks...it will check all the cable outlets for most power units and let you know if you have lost a main power rail.
Antec 430-Watt... | Answered on May 23, 2010
try google. this is not manual central
Antec Computers... | Answered on Mar 04, 2019
Unfortunately, there are not many parts available off the shelf to repair these. It would be simpler to get a power supply with a greater wattage rating than the one you have now.
Antec Computers... | Answered on Dec 06, 2016
What kind of Internet connection do you have
DSL, Fiber, Cable? do you have a modem? Do you have a router? Are you connected via Ethernet cable or wireless?
In order to start any diagnosis I need the answers to these and maby some other questions
Antec Computers... | Answered on Jul 26, 2015
Who's power supply?
Antec Computers... | Answered on Dec 25, 2014
What do you need to know about the "Wiring"?
Look at event log of Windows under management for any errors. Also run speedfan and check out your temps to make sure that its not a temp alarm for the CPU etc.
What about it?
So what do you need?
Do not understand the question
And what might the problem be?
I don't understand the question!
Maybe Black, White, Green. I do not quite understand what you need to know.
For 120 volt operation use
black for the hot, White for the natural, Green for earth ground.
For 240 volt operation use;
Black and White for the 240 volt and Green for earth ground.
Black is generally designated as the "Hot" or "positive" .
You must make sure the switch on the power supply is set for the voltage you are using. ie: 120/240
Recheck all your board connections. I missed a connector by one pin and got nothing as you have. Once I realized my mistake and re connected the plug on to the board correctly everything worked.
Antec Computers... | Answered on Oct 05, 2014
so check the cable....
some computers beeps because something is plugged not correctly....
I guess it's memory ....
try to remove and plug in back memory cards
Antec Computers... | Answered on Jan 13, 2014
If everything is working, those wires may be extra for expansion needs. There are several wires not connected to anything inside a PC
Antec  430-Watt Power Supply Logo
1 questions posted
Top Antec Computers & Internet Experts
Dimitar Todorov
Anthony Ward
Anthony Ward
Lawrence Oravetz
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Antec Computers & Internet
Most Popular Question
430 watt power supply my computer does n
  • Computers & Internet
