20 Most Recent RCA RCR-3283 Remote Control Questions & Answers
What is the code for
You can download the complete instruction manual and the list of programming codes in PDF format from the manufacturer's support website by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Your television brand is not listed in the codes list. So, you will have to try and manually search for the codes as described on page 3 of the manual.
Hope this solves your problem. Thanks for using FixYa.
7/13/2010 12:31:02 PM • RCA RCR-3283... • Answered on Jul 13, 2010
No manual
if it's a universal remote, rca has a website where you can download the program codes or the manual. rca.com, then select accessories, then downloads.
10/13/2009 9:16:52 PM • RCA RCR-3283... • Answered on Oct 13, 2009
I need to reprogram my remote to run my TV...help
IF IT IS AN RCA SYSTEM 3. HOLD CODE SEARCH TILL LITE ON PRESS TV (OR) AND CONTINUOUSLY PRESS AND RELEASE POWER BUTTON UNTIL RESPONDS
10/10/2009 3:47:29 AM • RCA RCR-3283... • Answered on Oct 10, 2009
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse . TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
1/21/2024 8:13:40 PM • RCA Televison &... • Answered on Jan 21, 2024
What is the code for remote control for RCA model# RT 1971-AC
Better idea https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com https://www.amazon.com > Replacement-DETG160R-... Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control. US$32.99 · ‎In stock
RCA RT1971AC Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem... If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems. US$34.90 RCA Universal Remote Codes:
  • The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
  • The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
  • The cable box codes are: 000 and 027.
Apr 26, 2023
RCA Universal Remote Codes List 4 Digit - GenTwenty
12/27/2023 12:47:10 AM • RCA Televison &... • Answered on Dec 27, 2023
Rca remote r26211 code for trutech tv dvd
Better to get a Facsimile Remote, a copy made for the unit. It is unlikely, you can input codes to work both applications in a combined set.
TruTech TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > trutec... Universal remote codes for TruTech TV sets - 3 digit, 4 digit and 5 digit codes.
My mom has a Trutech combination TV/DVD, about 20 ...
JustAnswer http://www.justanswer.com > TV Problems Feb 6, 2013 - There are very few universal remotes that will operate a tv/dvd combo and of ten if you find a code then the tv a dvd have separate codes. 1 answer · Top answer: Jack : Hi and welcome to justanswer. To answer your question; There are Make sure you use the FULL Model Number for it.
TRUTECH TV Replacement Remote
Remotes.com https://www.remotes.com > trutech-remote-controls-s Replace new & discontinued remote controls for TRUTECH devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Trutech Remote for sale
eBay https://www.ebay.com > ... > Remote Controls Sort ; 2PCS Remote Control For TruTech KLV3170 LCD Drop Down TV Built-in DVD Player · $13.83 ; TruTech A60P0315 Remote Control Genuine OEM TESTED · $3.00 ; Original ...
Trutech Remote Control
Amazon https://www.amazon.com > trutech-remote-control > k... GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, TCL, Panasonic, Smart TVs, Streaming Players, Blu-ray, DVD, 4-Device, ...
12/20/2023 1:17:20 AM • RCA Televison &... • Answered on Dec 20, 2023
I dropped my RCA remote control, how can I reestablish connection with Magnovox tv?
Check that the batteries haven't become disconnected. Do the Smartphone camera test to see if it is transmitting a signal. If it isn't, buy a remotes specially made for the Magnavox rather than an RCA Universal. Google Magnavox (model) remote control replacement. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/30/2023 4:26:09 PM • RCA Televison &... • Answered on Nov 30, 2023
My old Panasonic TV set has no video RCA slot. Only audio R and L slot available.
tv is not a smart tv, may have to replace it.
11/27/2023 3:30:48 PM • RCA Televison &... • Answered on Nov 27, 2023
How do I program an RCA TV with a Panasonic universal remote control e u r 7722x40
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote RCA Universal Remote Codes: For the RCA Universal Remote, there is a total eight different codes for RCA TV's and nine for VCR's. There are two different codes for cable boxes:
11/19/2023 5:44:36 AM • RCA Televison &... • Answered on Nov 19, 2023
Will RCA DRC8335 finalize discs recorded on RCA DRC8312 ?
Depends on the software you are using; ExpressBurn, Movavi etc will finalize.
11/13/2023 5:50:11 PM • RCA Televison &... • Answered on Nov 13, 2023
How to add external rca jacks to the output
To connect your audio receiver to your Proview 3200 flat screen TV, you can use RCA cables. Here are the steps: Locate the RCA jacks on your TV and audio receiver. One jack is white, and the other is red. Plug the white RCA cable into the white jack on the TV and the red RCA cable into the red jack. Reversing them will cause the stereo signal from the TV to be incorrect. Take the other end of the RCA cables and plug the white and red ends into an available RCA input on the back of your audio receiver. If your TV doesn't have RCA jacks, you can use a digital-to-analog audio converter to connect your TV to a 5.1 audio system that has only RCA inputs 1. You can follow these steps: Unbox the digital-to-analog converter. Connect the optical cable to the converter. Connect the RCA cable to the converter. Connect the other end of the RCA cable to an available corresponding analog audio input on your audio receiver
10/30/2023 4:08:01 AM • RCA Televison &... • Answered on Oct 30, 2023
2answers
Adjusting the brightness on the tv for a rca tv
make sure you have the original remote for the Tv and follow the steps below RCA Color TV User Manual Picture Settings
8/31/2023 4:35:34 AM • RCA Televison &... • Answered on Aug 31, 2023
I want to play the sound from my digital TV through my Yamaha AX-396 do I need a converter from digital TV to the amplifier?
The HDMI to RCA cables are intended for A/V devices like projectors that understand how to translate the digital signal to an analog signal. Your amplifier will not be able to do this. What make/model TV do you have? I don't know of any with HDMI outputs. Most only have HDMI inputs. What is your TV source (OTA/cable RF, set-top box, streaming device)? Does your TV have any audio out (digital audio output - fiber-optic or coaxial)? If you have an HDMI source, you could use an Audio Extractor. See https://www.amazon.com/HDMI-Audio-Extractor/s?k=HDMI+Audio+Extractor . You probably will need an extra HDMI cable and depending on the model either an RCA audio cable or a AUX to RCA cable. Plug in the source to the extractor's HDMI In, connect the HDMI Out to an HDMI input on the TV. Connect the extractor's analog audio output to one of the Yamaha AX-396 Audio IN connections. Connect the power adapter to the extractor and plug it in. Then turn on all of the components of your home theater system. (Probably you won't need to connect the HDMI out of the extractor back to the TV if your TV does have an HDMI out.) If your TV has a digital audio output, you could use a digital to analog audio converter. https://www.amazon.com/DA-Converters/b?ie=UTF8&node=3224445011 lists some options. Again you may need to purchase extra cables. Not all models are sold with the needed cables. I hope this helps. Cindy Wells (note: you can expect any converter to have signal loss.)
8/28/2023 5:54:13 PM • RCA Televison &... • Answered on Aug 28, 2023
2answers
I am getting no sound when on TV sound.
Yes, to get sound from your Roku TV to your receiver when using the TV's built-in apps (such as switching to TV sound), you might need more than just RCA cables. RCA cables only carry analog audio signals, and many modern devices, including Roku TVs, use digital audio signals for better quality. Here's what you can do to ensure you're getting sound from your Roku TV to your receiver:
  1. Check Audio Settings on Roku TV:
    • Go to your Roku TV's settings menu.
    • Look for the audio settings section.
    • Make sure the audio output is set to the correct option for your receiver. This is usually HDMI ARC (Audio Return Channel) or Optical audio.
  2. Use HDMI Cable with ARC Support:
    • If your receiver and TV support HDMI ARC, connect an HDMI cable between the ARC HDMI port on your TV and the ARC HDMI port on your receiver.
    • Ensure that the HDMI input on your receiver corresponds to the HDMI ARC output on your TV.
    • In the TV's audio settings, select HDMI ARC as the audio output.
  3. Use Optical Cable (if no HDMI ARC):
    • If your TV and receiver don't support HDMI ARC, you can use an optical audio cable (Toslink cable).
    • Connect one end of the optical cable to the optical audio output on your TV.
    • Connect the other end to the optical audio input on your receiver.
    • In the TV's audio settings, select optical audio as the audio output.
  4. Configure Receiver Settings:
    • Ensure that your receiver is set to the correct input source for audio. For example, if you're using HDMI ARC, select the corresponding HDMI input on your receiver.
  5. TV App and Volume Settings:
    • When using apps on your Roku TV, make sure the volume is turned up and not muted within the app itself.
    • Adjust the TV's volume settings to an appropriate level that allows your receiver to amplify the sound effectively.
  6. Test with Different Content:
    • Test the setup with different apps on your Roku TV to ensure that the issue is not specific to a certain app.
If you've tried these steps and are still not getting sound from your Roku TV through your receiver, it's possible that there might be compatibility issues between your TV and receiver. You could also try reaching out to Roku's customer support or your receiver's manufacturer for further assistance.
8/6/2023 8:09:45 PM • RCA Televison &... • Answered on Aug 06, 2023
RCA RCR-3283 Remote Control Logo
6 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
no manual
  • Televison & Video
