20 Most Recent Lorex L19wd804251 19 Lcd Dvr Surveillance System With 4 Weatherproof Cameras Questions & Answers
Should be1234 unless u have changed it
Lorex... | Answered on Apr 20, 2017
Monitor doesn't come on. It comes on for friction of second when I press on/off button and when I restart it. Anyone have solution for that
Lorex... | Answered on Apr 19, 2017
try to plug that camera to monitor directly it can be problem with its cable or BNC connector
Lorex... | Answered on Apr 25, 2016
SIMPLE !! YOUR GONNA NEED A ADDNL ITEM CALLED A RECIEVER AND THERE SPECIFIC TO TYPE OF WIRELESS CAMMERA YOU HAVE SO CONTACT IT'S MFG FOR THIS DEVICE
Lorex... | Answered on Dec 05, 2014
Native resolution of the display is 1288 by 760. If you need to replace the monitor I can supply a list of replacements, just ask if U need.
Lorex... | Answered on Jun 23, 2013
hi krol, shut down the system , unplug it for at least for 30 seconds , unplug the hard drive from the main board , (if you have two or more need to be unpluged all ) reconnect them and start it the system , it should work, it worked for me.good luck. t.saeed
Lorex... | Answered on Sep 17, 2012
at the deli you need to port forward in your router the web port witch is normally 80 to the ip of the machine.
Lorex... | Answered on Dec 29, 2009
try swapping the cam inputs first to rule out the unit, if not the camera may be faulty or needs setting up properly with a focus adapter, or the lens could need setting up!
when CCTV company's set up these systems they have all the equipment to plug in and focus auomatically etc..
Hope this helps!
Try looking at www.digitalvideos.co.uk (test equipment) section.
Lorex... | Answered on Sep 22, 2009
Replace the power adapter.
Lorex Home... | Answered on Jun 10, 2020
https://www.youtube.com/watch?v=hVr-DlmNock
Lorex Home... | Answered on Mar 20, 2020
Contact Lorex direct. The manual has no Factory Reset options, just return to Default settings
Ad www.lorextechnology.com/‎
‎+1 888-425-6739
Lorex Home... | Answered on Mar 05, 2020
needs to port forward in router at home.
this means outside global world >>> Your router Global IP ADDRESS >> .....YOUR Home Router .....>> Port forward >> internal IP address Camera using on your home network
https://www.youtube.com/watch?v=SEKqtc5bnxU
Lorex Home... | Answered on Jan 02, 2020
would first check the plug in power unit is giving correct output (by substitution) first .
Lorex Home... | Answered on Nov 02, 2019
red + 12v
black -
yellow video out
green video ground
Lorex L19wd804251 19 Lcd Dvr Surveillance System With 4 Weatherproof Cameras Logo
18 questions posted
Top Lorex Home Security Experts
Alphanso Tee
Fred Kommeroh
Level 1 Expert
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
View Most Popular
Lorex Home Security
  • Lorex Home Security
Most Popular Question
channel 3 camera 3 not displaying
  • Home Security
