20 Most Recent Sony KDF-E50A11E TV Questions & Answers
If the power cord is unplugged, then it must be a poltergeist.
Sony KDF-E50A11E... | Answered on Mar 14, 2015
Good evening,
In the command menu and go to the image you put in more contrast, brightness, etc ... this page can control the television picture.
Hope this helps
Lurdes
Sony KDF-E50A11E... | Answered on Oct 01, 2012
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
Sony KDF-E50A11E... | Answered on Feb 08, 2012
it could be a cooling fan or power supply problem or a switch on the saftey inter;lock on the lamp door
it will require some trouble shooting if your having problems finding some one in your area contact sony for a referal to a servicer in your area
Sony KDF-E50A11E... | Answered on Jul 09, 2011
Tries tv unplug,replug it back like about an hour later,now the tv should be resetting itself back to the factory setting.The tv now should be working agin.If tv still have the same problems,mean the tv power supply board it is the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Sony KDF-E50A11E... | Answered on May 14, 2011
How many hours are on the set? It sounds like the lamp is going bad, and won't let the power supply turn it on... Give that a try first and we will go from there. Good luck HDTV GURU JAY
Sony KDF-E50A11E... | Answered on Mar 18, 2011
So what exactly is the problem?Sorry I could not get it from your initial post. Please describe the problem in as much detail as you can so that I can help you solve your problem.
Sai.
Sony KDF-E50A11E... | Answered on Oct 25, 2010
my mistake, had the arial plugged into analogue and not digi port, as they are not labeled up as different
Sony KDF-E50A11E... | Answered on Aug 10, 2010
Lamp replaced and problem solved.
Sony KDF-E50A11E... | Answered on Aug 24, 2009
A common point of failure in LED backlight television is one LED will fail and the power supply wont come on. Many people replace the power supply board and it wont repair the problem. You have to replace the LED light strips.
Sony Televison &... | Answered Yesterday
Press and hold the "Setup" button, which is located in the top left corner of the remote. The light at the top of the remote should start flashing. Now, hold down the "TV" button located on the top right corner of the remote and enter the code simultaneously.
https://www.techwalla.com/articles/how-to-program-a-sanyo-universal-remote
Sony Televison &... | Answered 2 days ago
Problem is a bad capacitor on the power board. Caution if repairing yourself as capacitors in TV's hold a charge long after set is powered off and can be lethal.
When looking at your power board for a bad cap look at the top of the capacitors. A bad cap will have a noticable "bulging" on the top of it compared to others. Be sure to note polarity of capacitor (will have a "-" on one side indicating negative. To fix on/off issue simply unsoldered bad capacitor and solder in a new one with same voltage and capacitance rating being sure the new capacitor is oriented the same as the old one was before it was removed.
Sony Televison &... | Answered on Mar 31, 2020
Sony KDF-E50A11E TV Logo
28 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
hello i have a
  • Televison & Video
