20 Most Recent Haier HLT71 7 in. Portable TV Questions & Answers
What does it mean when it says no database?
It means there is no Database.
The data base is were all information is.
The database in this circumstance I would assume is the Memory card
8/28/2014 2:03:24 AM • Haier HLT71 7... • Answered on Aug 28, 2014
Is there any way to add more channels or delete
Haier HLT71 is a digital TV, that meanthis tv can recive digital broadcast.
A digital tv have 8 program each channel. Not like analog tv that only 1 program each channel.
So, if you want to save 1 channel , 8 channel will automaticaly saved as well.
Thats imposible to save or delete from your program.
7/20/2014 6:24:02 AM • Haier HLT71 7... • Answered on Jul 20, 2014
2answers
WHAT IS THE PORT UNDER
This is a Star Trek GNDN USB mini port for the Haier factory to update the firmware (software stored permanently) in the TV.
If you return the set to Haier for servicing under the 90 days labor, 1 year parts warranty, Haier will probably just send you a refurbished unit.
Part of the refurbishment is for the Haier factory to update the software which runs this digital TV.
If you connect your computer to the port with the correct cable, nothing will happen.
No drivers or user mods (hacks) appear to be available.
6/30/2014 3:59:35 PM • Haier HLT71 7... • Answered on Jun 30, 2014
0answers
0answers
No sound on one channel
If it's the only channel it seems it may be the channel that is being broadcasted.
8/31/2012 8:02:05 PM • Haier HLT71 7... • Answered on Aug 31, 2012
I see a no data base what can i do
It says no data base because it has not found any channels that are acceptable.Not all areas of the country or the world would have the same base of channels so that is why it has none when first used.It needs to scan the air waves to build the data base for its current location,if you were to move or take the HLT71 on a trip you would have to do this again. Also unless you live in a highly populated area you will need to use an outdoor hdtv antenna as the antenna that comes with it is not powerful enough.The TV is great but the digital technology used for broadcasting is just not that good yet. You can also hook it up to cable or satellite. Good luck and I hope this helped.
8/12/2012 12:59:54 PM • Haier HLT71 7... • Answered on Aug 12, 2012
Need code to turn tv on for haier model HTF20R21 tv?
Is it a Haier remote? Haier customer service person says that no Haier flat screen TVs or, for that matter, DVD players, are set up to be able to work with a universal remote; only their older tube TVs do. The Haier remote must be used. So we all can stop trying to find the codes. It wold have been nice is the user guides had revealed this unfortunate absence of functionalityReplacement on the Haier website is $19.99 plus a load in shipping. I am not sure if your remote has a search code function, Most do. Check your instructions. I proceeded to go one by one through our remote's TV codes with the search code function, pushing the power switch after each code, until the set turned on. Hope some of this helpsRead more: http://wiki.answers.com/Q/What_is_the_universal_remote_code_for_a_haier_tv#ixzz1kUnuLc2r Read more: http://wiki.answers.com/Q/What_is_the_universal_remote_code_for_a_haier_tv#ixzz1kUnRB5An
1/25/2012 9:49:30 PM • Haier HLT71 7... • Answered on Jan 25, 2012
I am receiving a no
It says no data base because it has not found any channels that are acceptable.Not all areas of the country or the world would have the same base of channels so that is why it has none when first used.It needs to scan the air waves to build the data base for its current location,if you were to move or take the HLT71 on a trip you would have to do this again. Also unless you live in a highly populated area you will need to use an outdoor hdtv antenna as the that comes with it is not powerful enough.The TV is great but the digital technology used for broadcasting is just not that good yet. Good luck and I hope this helped.
11/16/2011 8:45:13 AM • Haier HLT71 7... • Answered on Nov 16, 2011
I need a antenna that have a good strength to get
Tries websites like Amazon.com,Ebay.com to buy a Digital design antenna for a better strength longer ranges.But many of these antennas are design for mostly big tvs sit on a table tops.Just look for many of those digital design antenna choices,one of them will be snall enough and portable enough to carry with ur portable tv.
6/4/2011 7:33:19 PM • Haier HLT71 7... • Answered on Jun 04, 2011
Haier HLT71 7 in. Portable TV Logo
49 questions posted
Top Haier Televison & Video Experts
Jaime Hernandez
Paul Bade
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Televison & Video
Most Popular Question
any way add more channels or delete
  • Televison & Video
