20 Most Recent Panasonic TH-42PX6U Plasma TV Questions & Answers
I am getting a 7 blink code what part # do I need and where can I get it
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
8/15/2015 1:18:15 PM • Panasonic... • Answered on Aug 15, 2015
Remote control for tv stopped working
Check the batteries... Try a cheep universal remote .... Contact the maker of your TV.
1/27/2014 8:45:09 PM • Panasonic... • Answered on Jan 27, 2014
No reception with rabbit ears
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
10/24/2012 11:30:59 PM • Panasonic... • Answered on Oct 24, 2012
Password
There is no other way to change the password to this model set. You have to consult the dealer for further advice, as its manual says.
7/8/2012 1:41:15 PM • Panasonic... • Answered on Jul 08, 2012
I want to reset the
my tv have 3 broad lines on the screem
6/26/2012 5:34:02 PM • Panasonic... • Answered on Jun 26, 2012
My TV does not turn on power and the red right on
When you have your televisions standby light blinking for about some time, it means there is a power problem affecting the television. It is recaiving power but not using it up.
The power problem is most likely caused by a bad capacitor or a bad power panel. The bad capacitor can either be on the main panel or the power panel.
To confirm, unplug your television for about an hour or two so the high voltage will dissipate, then you unscrew the screws that are at the back of the television to gain access to the main and power panels, then you carefully turn the back of the panel where you have the capacitors and check for bad capacitors, if it looks swollen, compressed, of burnt, then it is faulty.
The solution to that is for you to turn to the other side of the panel where you have the tip of the capacitors and melt off the burnt capacitor using a soldering iron, then fix in an new capacitor with the same capacity in the holes and solder it to the panel. Then cut off the extra tips of the capacitors, then fix the panel back on the television and couple it back together.
After doing that the television will be in good condition once again, and if there are no bad capacitors on both panels, then it means the power panel is faulty and needs to be replaced.
Take care and good luck.
10/26/2010 5:21:50 AM • Panasonic... • Answered on Oct 26, 2010
Hello, I have a Panasonic TH-42PXD6U HD Plasma
It is most likely that someone in your neighborhood has a similar TV.
6/15/2010 8:34:00 PM • Panasonic... • Answered on Jun 15, 2010
We cannot control the volume
Hi.
the TV goes in standby and does not wake up, because the control board is sending TV on protect mode after detecting a fault.
When this happens higher voltages from psu get shut down to prevent further damage.
20 Blinks is not an error code, but I will do some more research on this.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
11/19/2009 6:36:11 PM • Panasonic... • Answered on Nov 19, 2009
The tops of everyones head is cut off the bottom
Check your manual and change your aspect ratio.
if thats not it check your controller board.
for more info/ detail make a new post with the make and model of your TV
For a used one check www.rns-systems.com
10/16/2009 6:11:31 AM • Panasonic... • Answered on Oct 16, 2009
We have a Pensonic led 3216 led cut, when we try to open it the screen is all black how to fix it? how to do a reset n the tv
Not totally sure what your asking but I think your saying your LED lamps aren't working, if that's the case replace them
10/15/2021 10:33:14 PM • Panasonic TH... • Answered on Oct 15, 2021
0answers
Tx-p42ut50b
Be the first to answer 6/5/2014 12:19:19 PM • Panasonic TH... • Posted on Jun 05, 2014Be the first to answer
Random Side Panel Inputs
You either have a bad Main board or simply a bad touch control button in other word one of your side buttons is defective and it is blocking any other signal to the main board, but usually its a bad main board. In some cases ther is a FIRMWARE update from Panasonic, you may want to call Panasonic or check there website for any type of FIRMWArE UPDATE.
5/10/2014 11:34:00 PM • Panasonic TH... • Answered on May 10, 2014
0answers
Hdmi problem
Be the first to answer 4/23/2014 3:36:40 AM • Panasonic TH... • Posted on Apr 23, 2014Be the first to answer
Panasonic TH-42PX6U Plasma TV Logo
21 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
am getting 7 blink code part need get
  • Televison & Video
