20 Most Recent
Mitsubishi WD-73837 73 in. HDTV Questions & Answers
73in Mitsubishi tv
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. .
WD 73837 HAS MENU PROBLEM.ALL MENUS WILL NOT FUNCTION WHEN ACCESSED.AFTER ACCESSED THE TV CAN ONLY BE SHUT OFF BY USING THE CONTROL PANEL.
Sounds like corrupted firmware. Contact any service technician. However, try a reset to this set, and check before doing a firmware update. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
What can be done to repair
This is usually due to physical damage from the screen being touched or bumped. There is no way to repair.
I get sound but no picture then the tv shuts off after 5min. It is a Mitsubishi wd-73837
Popping noises are not a good sign; I suspect the sound came from the catastrophic death of an electrolytic capacitor or worse, the death a a power semiconductor.Open the lower cabinet and using a good light, look for a smaller, separate board with fairly large parts on it; some cylindrical in shape, others block-like that may have copper wire showing.If, as common, this board is plugged with connectors into other parts of the system, you may be able to swap the failed board out for a replacement bought from a Mitsubishi service center.Expect to pay $100-$150 US if the set is no longer under warranty.
11/23/2011 10:07:25 PM •
Mitsubishi...
Answered
on Nov 23, 2011
How do you change from tv to DVD player
First, connect your DVD player to the TV then. Second, change the source by pressing Activity on the remote.
You can read the user guide here http://a248.e.akamai.net/pix.crutchfield.com/Manuals/690/690WD73737.PDF
Best of luck
AAA TV SERVICE
http://www.aaatvservice.com
Mitsubishi wd-73837 doesn't turn on at all, no
I'm sure it's nothing you did wrong. I maybe a blown fuse inside causing the problem or a bad power supply. But, I wouldn't open up the TV. It may void the warranty by playing around inside.
Best to take it back and exchange it for another one. Tv repairs now and days cost an arm and a leg. Use warranty to full advantage.
