20 Most Recent
Philips 32PFL3504D 32 in. LCD TV Questions & Answers
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
11/1/2017 9:40:16 AM •
Philips...
Answered
on Nov 01, 2017
I have a boken screen can't seem to find a
Hello; If you could find a new LCD Panel, It will cost more than double the original selling price of the set. Unless the set is of extreme nostalgic importance, toss it. John
7/6/2011 1:22:13 AM •
Philips...
Answered
on Jul 06, 2011
Tv say "no signal" when
Hmm your PS3 should not be using AV out because your game signal is going into your TV, Try using HDMI 1,2, or 3 also there should be av in components in your TV as well.
7/2/2011 10:40:27 PM •
Philips...
Answered
on Jul 02, 2011
We have a Philips 32in
first,
make sure the TV is correctly plugged into the wall. You can try
another outlet. If that doesn't work, then your TV is certainly having a
power problem.
The issue you describe is consistent with a power
supply board issue. This is the board where the AC goes to. This
problem may have occurred as a result of irregular power supply, or
excess power supply or power surge.
The TV is receiving current
but cannot circulate or transfer the current to other necessary part of
the TV because of the defective power supply board. You might be lucky
it's just a blow fuse. Also a defective transformer can cause your TV
not to power on......
All these can be checked on the power supply board.......
But
more often bad capacitors causes problem on the power supply board. I
do not think the power board needs replacement, rather those defective
capacitors is causing this issue. Open unit up and take a look at the
power supply board.You will probably see one or more electrolytic filter
capacitors that are bulged up in the top-not perfectly flat like the
others.
The value of these capacitors will be different, most
likely they will be somewhere around-820 to 2200uF/25 V( or /10V
sometimes).
You can replace them with same values but I would
recommend the voltage rating to be higher(like 35V for an original 25V)
for reliability purposes.
What happens is,these bulged top
capacitors will cause a low and unfiltered DC voltage=main board will
malfunction(the relay will keep clicking until the caps are holding
enough charge to bring the voltage up over a threshold point).
You
can buy these capacitors at any Fry's or Radioshack store or you can
order them online at vendors like "mcmelectronics.com"(look for
electrolytic capacitors). After replacing these capacitor(capacitors)
most likely the normal operation will be restored. Or you can by a
refurbished complete power board to save you some stress.......
Note:
There may be also some other causes for this symptom ,like a defective T
con board ,or main board,but the bulged top capacitors are the most
common cause for this issue.
If you don't know about TV repairers,
take the TV to the nearest repairman to fix the fault for you. Also,
note that TV stores a lot of current, so wait a while before opening the
TV back cover.
Yours sincerely.
Elect_Comp.
5/16/2011 11:39:48 PM •
Philips...
Answered
on May 16, 2011
Lost my remote and tv
Yes there is a way around zooming in and out without the television remote control. The cable box/satellite tv receiver also has an option to zoom in and out on it. BUT it usually only works when you have the hd box/receiver AND the television has to be on the right input in order to receive hd (component input or hdmi input). PLUS the cable box/satellite receiver should be set on the 1080i resolution (or 720p depending upon the resolution the television can accept). Then you can find the button on the remote that says #hd zoom (yes the # sign is on the button) or the button may be format or aspect.
2/8/2011 5:00:59 PM •
Philips...
Answered
on Feb 08, 2011
I am tring to connect my PC to my philips
for the plasma tv, go to the menu and try to find some options about the HDMI on the menu or go through the user manual you will definitely find some solutions. or try to change the HDMI cables.
8/10/2009 12:04:47 PM •
Philips...
Answered
on Aug 10, 2009
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
