20 Most Recent AOC L32W861 32 in. LCD TV Questions & Answers
como programo la tele smart aoc para que prenda sola a una cierta hora?
AOC L32W861 32... | Answered on Nov 05, 2018
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
AOC L32W861 32... | Answered on Nov 01, 2016
Try this to reset your monitor:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
AOC L32W861 32... | Answered on Jun 26, 2016
Try this:
It sounds to be a T'Con fault. Contact any service technician to confirm. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Check the site in 'Mosaic' view.It will make search easy.
AOC L32W861 32... | Answered on Jan 05, 2014
Buy THIS main board, and replace it. Most of the time, this should fix your no picture, no sound issue.
AOC L32W861 32... | Answered on Jan 31, 2013
You can do this manually throught he menu and using the volume/channel buttons to toggle to the choices. Go to the video menu and in there you will be able to adjust the display size.
AOC L32W861 32... | Answered on Jan 24, 2013
AOC L32W861 32 in. LCD TV Logo
39 questions posted
Top AOC Televison & Video Experts
Jayesh Panchal
Jayesh Panchal
Marvin
Marvin
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • AOC Televison & Video
Most Popular Question
sound goes out random
  • Televison & Video
